Heavier oil in V6????
Old Apr 17, 2014 | 07:35 AM
numnutz's Avatar
Has anyone experienced any problems in switching to heavier oil in 2012 V6? Mine has reached 55k and 5w20 seems a little thin for it now, as I'm getting noise on light acceleration that sounds reminiscent of old school main bearing knock. Very faint, but a little disturbing. Thanks in Advance for your input.
Old Apr 17, 2014 | 07:21 PM
SMBJoshy's Avatar
I've read that the cam phasers are pretty sensitive to viscosity changes, not sure how true it is though. Unless you drive the hell out of your car on a daily basis, it wouldn't make any difference switching to a heaver eight.
Old Apr 17, 2014 | 07:25 PM
Joeywhat's Avatar
I would just stick with the recommended 5w20...
Old Apr 17, 2014 | 07:44 PM
Ltngdrvr's Avatar
I think you're hearing things, imagination can be pretty persuasive.
The motor is designed for the lighter oil.
Old Apr 18, 2014 | 10:33 AM
StangDawg's Avatar
You may want to read this info on this link before you change the oil weight. The oil weight also impacts the oil pressure. I would also check with a mechanic or a dealer to find out if the noise is normal for your mileage and year. Let us know what you find out.
Old Apr 18, 2014 | 11:16 AM
2011 Kona Blue's Avatar
I use 5W 30 weight oil in my 2011 3.7 from the beginning of ownership and no issues of noise or ticking from the engine.
Old Apr 18, 2014 | 11:17 AM
numnutz's Avatar
Thanks for all the input; soon as I get all the eggs hidden, and recoup from the festivities, I'll get my trusted? mechanic to give it a listen. My hearings bout shot, and I cannot tell if this is lower engine or something in exhaust giving the faint, low knocking sound on light acceleration. Thanks again.
Old Apr 18, 2014 | 11:03 PM
SpeedyJoe's Avatar
I even changed to mobil1 0W 40 with no issues, the engine sounds much quiter from the start on and stays that way.
Old Apr 18, 2014 | 11:09 PM
Ltngdrvr's Avatar
That description of the sound sounds to me like pre-ignition ping.
They all do it to a certain extent, it's the way the pcm works to get the best power and economy out of the engine.
Old Apr 19, 2014 | 06:37 AM
numnutz's Avatar
Read everything on the links StangDawg provided; very informative. Going to start with exhaust as soon as some of the younger family gets in, with good ears. Thanks again guys.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
