Heavier oil in V6????
Has anyone experienced any problems in switching to heavier oil in 2012 V6? Mine has reached 55k and 5w20 seems a little thin for it now, as I'm getting noise on light acceleration that sounds reminiscent of old school main bearing knock. Very faint, but a little disturbing. Thanks in Advance for your input.
I've read that the cam phasers are pretty sensitive to viscosity changes, not sure how true it is though. Unless you drive the hell out of your car on a daily basis, it wouldn't make any difference switching to a heaver eight.
You may want to read this info on this link before you change the oil weight. The oil weight also impacts the oil pressure. I would also check with a mechanic or a dealer to find out if the noise is normal for your mileage and year. Let us know what you find out.
Thanks for all the input; soon as I get all the eggs hidden, and recoup from the festivities, I'll get my trusted? mechanic to give it a listen. My hearings bout shot, and I cannot tell if this is lower engine or something in exhaust giving the faint, low knocking sound on light acceleration. Thanks again.
They all do it to a certain extent, it's the way the pcm works to get the best power and economy out of the engine.
Read everything on the links StangDawg provided; very informative. Going to start with exhaust as soon as some of the younger family gets in, with good ears. Thanks again guys.
