Gauge Cluster lens 2010
Old Oct 16, 2025 | 06:26 PM
inky86's Avatar
I have a base convertible 2010 mustang that hasn't been taken very good care of. I know, it's a base,auto,convert and 4.0 v6 but it's what i have to work with.
I am trying to find out if it's possible to change the clear lens cover on the gauge cluster. Looks like someone used a harsh cleaner on it as it is scratched and cloudy in spots.
I pulled the outside trim off and it looks like someone has already tried to remove the clear lens as it has a crack and a couple chips. I don't want to go through the expense of buying a whole new cluster and trying to get it cloned as the one i have works fine.
Hoping it isn't glued on but i can't find the lens cover for a 2010. Seems 2010 is the frankenstein year for the mustang...
thx!
Old Oct 16, 2025 | 06:39 PM
05stangkc's Avatar
If You Have a 4 Gauge Cluster Those are Pretty Rare. They Are Replaceble But Discontinued By Ford! Here is a Used Cluster That Seems Pretty Reasonable! Make Sure They are Sending Lens With Cluster! Might Want To Call!
Edit!
This One On Ebay Looks Great!
Bottom Line All you Need is Cluster Face So Shop Accordingly!
https://ebay.us/m/sRGvdP
https://www.lkqonline.com/2010-ford-...fkL6p5nZkTHo0s
For Reference!
https://www.fordpartsgiant.com/parts...html?pnc=10890
Here are Others For 4 & 6 Gauge! Click on More Info For Pics!
https://www.lkqonline.com/2010-ford-...r-head-cluster
Hope This Helps With Your Repair!
Oh and I Looked in the FORD System and No Dealers Have Any Old Stock Laying Around For The Base 4 Gauge Mask/Lens setup! If You Have Mechanical Reset Button You Have That Style!
Old Oct 16, 2025 | 06:48 PM
inky86's Avatar
Thanks, not bad but just looking for the clear plastic lens, 3 pieces, not sure if they even come off. Cloning a cluster is more than i want to spend
Old Oct 16, 2025 | 06:53 PM
05stangkc's Avatar
I Guess You Did Not Look At This Link.
It Shows What You Would Have Got From Ford! Likely Snaps Together on Top of Cluster. I Was Only Suggesting Getting Cluster & Swapping Lens.
If You Got a New Cluster Form Ford It Does Not Come With Mask/Lens
If You Got a New Cluster From Ford It Does Not Come With Mask/Lens. So No Doubt it is Removable!
https://www.fordpartsgiant.com/parts...-10849-va.html
KC
Old Oct 16, 2025 | 07:04 PM
inky86's Avatar
ah ok, i see. Thought the 2 screws held the whole cluster in. I'll give this a try, thank you
Old Oct 16, 2025 | 07:08 PM
05stangkc's Avatar
Hope you Find a Nice One!
I'm Sure if Ford Still sold Them They Would Be SPENDY Anyhoo!
Make Sure Your getting Proper One as They Made 4&6 Gauge in 2010, Mechanical Reset 4 Gauge, Has Hole in Mask. 6 Gauge Does Not!
Kc
Old Oct 16, 2025 | 07:24 PM
05stangkc's Avatar
Doh!
Here are The Instructions!
Kc
File Type: pdf
File Type: pdf
ThatBlueMustang
'10-14 Interior and Audio
Jul 14, 2021 09:44 AM
black2006stang
05-09 Interior and Audio Mods
Dec 28, 2012 11:42 AM
Mazen
Apr 17, 2012 08:18 AM
chutoyy
Feb 27, 2011 01:48 PM
Mustangguy225
Sep 30, 2010 03:47 PM
