BBK Shorty header install
Old Mar 12, 2022 | 10:26 AM
Ryunker's Avatar
So this morning did the install of the shorty BBK's, went smooth no real issues. Before install did research on the web, many said right side was much ore of a job. I found the opposite, removed battery and tray leaving much room to work on the right side. All of the header bolts to head were done from up top. Only work under car was exhaust pipe flanges.
Left side was a bit more work as the steering shaft was in the way from positioning the header up to the head. Removed upper bolt from steering shaft allowed the header to fit.
Biggest part of the job was the lower header bolts on both banks. They are not easily accessible by any tool other than a combination wrench, took a bunch more time.
Old Mar 12, 2022 | 03:59 PM
m05fastbackGT's Avatar
Glad everything worked out on the shorty header install.. Meanwhile, thanks for sharing and welcome aboard.
Old Mar 13, 2022 | 09:19 AM
Siber Express's Avatar
Install on them is really quite simple, just time consuming. I did mine both times (First set had a bad weld on the flange to runner weld) with the Battery in.
1/6th of a turn Repeat
Old Mar 19, 2024 | 04:45 PM
Templarjj75's Avatar
Did you have to remove any of the studs?
Old Mar 19, 2024 | 04:54 PM
Ryunker's Avatar
What studs are you referring to?
Old Mar 19, 2024 | 05:46 PM
The studs for the manifolds/headers. I have seen that some need to be removed for header installation because they are too long? Getting ready to install mine so just reading and doing some research beforehand...
Old Mar 19, 2024 | 06:01 PM
Ryunker's Avatar
Do yourself a favor and stop research. This job is straight forward without surprises. Have patience and do one side at a time.
Old Mar 20, 2024 | 10:20 AM
I suggest you read over post #1 once again, as Ryunker did not mention anything about having to uninstall the studs while he installed his BBK shorty headers... I've also included a thread link below which provides additional information regarding the installation process...
In the meantime, welcome aboard!
https://themustangsource.com/forums/...nstall-528899/
Old Mar 20, 2024 | 02:31 PM
If you have BBK just make sure you put the nut on the right side like is listed in instructions.
Shigetas
Jul 31, 2010 01:27 AM
JMoraru
30
Dec 12, 2008 01:05 AM
edweiser63
Jan 5, 2008 07:49 AM
officespace56
48
Oct 4, 2007 02:46 AM
bored out
65
Aug 5, 2007 07:23 PM
