Axle backs
Old Mar 12, 2022 | 05:54 PM
Ryunker's Avatar
Axle backs
My car was purchased used a short time ago, it has loud exhaust. "Pype Bomb" mufflers are probably the closest thing to no mufflers at all. I have a set of "Ford Performance" mufflers on order from my local dealer for my 3.7l
What axle backs do you have along with the pros and cons you have experienced so I can feel better about my incoming parts.
Old Mar 12, 2022 | 06:11 PM
dusman59's Avatar
Just about anything you get will be better than those. I would think the drone would be terrible.
Old Mar 13, 2022 | 09:13 AM
Siber Express's Avatar
When I was looking at an axle back for my car it was down to Borla and FRPP Mufflers, I went with the Borla mainly because the tips were bigger. You are going from the Worst to one of the Best IMHO.
Old Mar 22, 2022 | 06:34 PM
Ryunker's Avatar
Went with the FRPP axle backs, came in this morning and just installed them. Very happy so far with the decision. Huge improvement. Chrome tips vs the black ones I took off.
Old Mar 23, 2022 | 04:29 PM
m05fastbackGT's Avatar
Borla manufactures the FRPP mufflers for all 2011-current Mustang models to FRPP specifications, which is the reason the tips have smaller 3.5" tips vs the larger 4" tips on the Borlas.
If these are the FPP axle backs that you ordered and installed? they're either FPP touring mufflers or FPP sport mufflers.. Both are manufactured by Borla for FPP.. Links and images are attached!
https://performanceparts.ford.com/part/M-5230-MV6CA
https://wwwqa.performanceparts.ford....t/M-5230-MV6LA
FPP Touring Axle Back M-5230-MV6CA
FPP Sport Axle Back M-5230-MV6LA
Old Mar 24, 2022 | 08:16 PM
DJ2014's Avatar
These are the ones I have. https://www.americanmuscle.com/magna...ck-2011v6.html There is some drone but not much.
Old Mar 24, 2022 | 08:17 PM
DJ2014's Avatar
Old Mar 25, 2022 | 07:21 PM
Ryunker's Avatar
So the only ones the local Ford dealer could order were the M-5230-MV6CA, other numbers were discontinued and this was it. They do appear cosmetically a bit different then the above photos as on the chrome tip, it just says Ford. Embossed on the muffler besides Ford racing, it is stamped "by borla" I feel they are the touring style as while steady driving they are decent quiet. Idling and running thru the gears, they mimic to me a stock standard gt sound.
As earlier, for me they are the correct choice, hands down. Even at a tad over $800 a set.
Old Mar 26, 2022 | 08:43 PM
The reason for the cosmetic differences over the above photos, is your touring mufflers M-5230-MV6CA are the latest revision, where as the photos I attached above were from older versions..
Nevertheless, they are the very same M-5230-MV6CA touring muffler manufactured by Borla for Ford Racing as posted above!
Old Apr 14, 2022 | 11:36 AM
CanuckCoupe's Avatar
I just bought the same car with the exception of a few additional scoops.
How is the exhaust at cruising speed? I just traded in My Rubicon with an AFE system and the drone was too much
Old Apr 14, 2022 | 12:54 PM
DJ2014's Avatar
If you are referring to me, there is some drone but not bad. I've had them on for so long now, I don't notice it anymore.
Old Apr 14, 2022 | 01:37 PM
Ryunker's Avatar
If you are asking about the Ford ones, silent at cruising speed, love them. Even at $850.
Old Apr 14, 2022 | 04:56 PM
And mine even with the Short Tubes and true X Pipe has none.
Old Nov 3, 2023 | 09:39 AM
13_3.7's Avatar
Their is a couple ford performance muffles in my area for sale. Are the GT axel backs the same as the V6 ones, Will they work in the
V6?
Old Nov 3, 2023 | 02:08 PM
If the pipe diameter size is the same, then yes... Otherwise, they will not fit properly on the V6.
Old Nov 3, 2023 | 02:11 PM
05stangkc's Avatar
I Think Diameter is Different!
If You Can get a Screaming Deal on the GT Mufflers a Muffler Shop Could Modify. But Do a Cost Check!
Exhaust Can Be a very Slippery Slope Though!
https://themustangsource.com/forums/...ameter-533087/
Kc
About Halfway Through These are Some V6 Vids With Some Exhaust Clips!
https://themustangsource.com/forums/...e-vids-550426/
nnn
Red Candy
Apr 16, 2014 09:22 PM
Varilux
Jul 3, 2013 01:14 PM
cdavila
May 30, 2013 05:23 PM
Dfink114
'10-14 Exterior Modifications
Dec 23, 2012 09:43 PM
