Is tuning REALLY necessary?
#41
I am not trying to be a jerk but rather understand the basis for your comment.
#42
Originally Posted by texastboneking
Cai only require a tune when they come equipped with a larger maf. So your comment is false.
Exactly why I said some CAI's come with an insert to run without a tune. So no I was not false.
If they do not have a no tune insert that limits the amount of air into the maf, then they require a tune.
#43
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by Tony Alonso
Have you actually tuned cars? I believe I read where you work on them. Also, are you familiar with all of the protection mechanisms in the PCM that controls the 5.0L engine?
I am a technician at a Ford dealership and I'm specializing in electronics and electrical.
And the protection the 5.0 Pcm has already been bypassed. It's the flash counter that you have to watch for.
#44
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
#45
Again no... They make Cai that do not require a tune and do not come with a insert.. bbk for example.
#46
A Man Just Needs Some....
There really is not much reason for a larger MAF unless TB and intake have been replaced. The larger MAF was something that was done on the old foxes that would only trick the PCM into letting more air in naturally. Bigger injectors more fuel etc. Just doesn't work like that any more.
#47
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Hate to burst everyones bubble... But a factory maf will draw in the same amount of air as an aftermarket maf of larger size. On a naturally asperated engine at least.
#48
#49
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by AlsCobra
That was not the case in the foxes. That's why they worked. The newer mustangs don't really gain anything from it.
#50
I'm talking obd2 here. I don't have any mustang pre obd2
#51
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Which most of the new MAF's are not restrictive at all. But aftermarket will sell you one that really produces no gains for a premium $. The world is full suckers.
#52
Theres really no point in running a CAI without a tune anyways.
Some people with the bbk have reported worse performance and gas milage, and the airaid gains are not worth it for the cost without a tune.
The stock intake is already very efficient.
#53
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
And you really don't need an intake at all. A tune will net you the same Hp gains as a Cai and tune combo.
#55
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by cdynaco
That's why you need a hood liner made for the CAI.
As for a tune giving you as much as no CAI, that contradicts the proven results from cold air.
![Headscratch](https://themustangsource.com/forums/images/smilies/headscratch.gif)
#56
Well mines not an airbox. The seal matches the hood liner so you can use the open style element. And it comes in from the front instead of a hot wheel well.
So an aftermarket open element CAI without a hood liner seal is defeating the purpose.
But I would think that (true) cold air + a tune is going to yield better HP than just a tune.
![](http://www.charliehorse.com/Engine%20CAI%20em.jpg)
#57
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
#58
#59
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
I thought that the 2010+ airboxes are actually pulling air from the front grille.
