Trans [6 spd] fluid info
#62
You can save 25%-30% depending on the product you choose...
#63
I had the TSB performed on my 2011 Mustang 5.0, it was manufactured in September 2010.
Before TSB
At low temperatures, below 30 Deg F, I could not go into 2nd. 3rd was difficult also. After warm up, things were much better.
After TSB
At low temperatures, below 30 Deg F I can actually shift into 2nd and 3rd and other gears easier. The fluid that Ford Dealer put in was the Motorcraft Dual Clutch fluid. I understand that the fluids from other manufacturers is typically per manufacturers specification or exceeds it, but a Transmission to me is an expensive items to repair. Especially when I paid so much money for a car,I want the manufacturer to stand behind the product.
In my case Ford Customer Service and the Local dealer both have records of the issue. If say in the 4 years less the 60K miles my transmission does fail I hope the original communication and repair actions help honor the warranty repairs. This is just my cautious approach.
I am impressed with Fords customer service, they contacted me promptly based on a string I posted here. My last experience with Toyota Customer Service was not so great since they said they can't help and the dealer can. My first and last Toyota ;-) was from 2002 to 2003.
Before TSB
After TSB
#65
I live in Phoenix so no cold weather issues here, but I noticed right away that my MT-82 didn't like to shift smoothly. My wife has driven the car twice and said that she had trouble shifting into second. At first I thought it was the skip shift, but after owning the car less than a week I disabled that and the shifting feel did not change. I just had my oil (Mobil 1 EP Gold Cap 5w30) and trans fluid (Red Line MTL) changed out with a bit more than 500 miles on her. She shifts smoothly all the time and I'm getting better mileage too! The oil came out of the motor like water and the trans fluid was more like cooking oil than gear oil. I would recommend changing the fluid of the trans sooner rather than later, My 2 Cents at least...
#66
Hello, Newbie here. I changed from factory trans fluid (dual clutch fluid --1/2012 build date) to this amsoil 75w-90 api gl-4 (mtg) at 900 miles and instantly noticed much smoother shifting through all changes; especially 1-2. Currently showing 1250 miles, and seems to be getting smoother all the time. Also switched factory shifter **** to a 400gram aftermarket, which made a BIG difference in felt shift effort and vibration during all shifts. It seemed to have made as big a difference as the fluid swap! I also swapped out factory oil to amsoil 5w-30 signature series at 700 miles. Will post back after 1400 miles with progress reports.
#69
If a car was built in August 2011, any idea which fluid was the factory fill? I think im right around the time of the change.
Everything is decent with my tranny but thinking of doing the Amsoil MTG
#71
Originally Posted by fake
You should have about 1/4 left in the 3rd bottle if you fill it to the correct 2.7qts.
#73
Originally Posted by Thamac15
How many of these diff fluid posts are you going to start?
#74
Originally Posted by Fintile
Does that include the rear diff as well? Also would it help to change the diff oil?
#75
The tranny fluid change will give you a noticeable improvement in shift feel and engagement. In my surfing, the RP trans fluid is not as compatible as the Red Line MTL which I use and Amsoil MTG. I haven't read anything about an improvement in changing the read diff fluid, only time will tell I guess.
#77
I've tried both. Redline was the smoothest but I switched to MTG because summers here are brutal. MTG is awesome right now but sucks when it's cold out for the first 5 miles or so. Redline got notchy when cold also. Both are huge improvements over the crap ford put in there.
#79
