Sponsored by:
Sponsored by:
Strut mounts req'd with Eibach ProSystem?
Old Oct 31, 2013 | 08:11 PM
mustangman55's Avatar
Are new strut mounts required with the Eibach prosystem?
I ordered it and have it here and I keep hearing that the factory mounts may break and I don't know what to do since I have about 25k miles
Old Nov 1, 2013 | 04:23 AM
kona stang10's Avatar
No they are not required , but highly recommended, simply because the stock mounts are weak and are 1 time use parts. Either upgrade to gt-500 mounts or do what i did, upgraded to steeda heavy duty mounts. They allow camber adjustments!
http://www.steeda.com/store/steeda-m...unts-555-8135/
Old Nov 1, 2013 | 05:52 AM
Bocefus's Avatar
They are recommended the stock mounts are one time use. Good luck trying to put them back on.
Looks like you are doing a mild drop so the gt500 mounts will work fine. I went with BMR springs and gt500 mounts allow enough adjustability for a proper alignment. Really no need to to drop $300+ on camber plates. Hope this helps
Old Nov 1, 2013 | 05:58 AM
Brandon302's Avatar
Unless the shocks and struts are the 05-10 style you can't use the GT500 mounts since the 11-14 style shocks and struts have a different top.
Old Nov 3, 2013 | 09:44 PM
Gtstyles2's Avatar
I have the Eibach Pro Plus kit and learned the hard way that the GT500 mounts DO NOT fit... Your only choice is either get new stock mounts or Steeda or Maximum Motorsports caster/camber plates
Old Nov 4, 2013 | 11:47 AM
V6 Driver's Avatar
Or camber plates from Maximum Motor Sports.
Old Nov 4, 2013 | 11:52 AM
Mr. V's Avatar
I have the ground control plates and they are excellent.
Old Nov 6, 2013 | 11:10 AM
Music man in Pcola's Avatar
I used Eibach F/R sway bars, Steeda Ultralite springs, and Steeda HD strut mounts to eliminate all unwanted noise. I retained my stock struts/shocks for now and will upgrade to Steeda 11-14 HD struts/shocks a bit later when the stock stuff gives up the ghost. So far zero problems, but I am ready for the better shocks/struts to fully complete my suspension.
samjluck
Oct 26, 2015 05:17 PM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
robjh22
Sep 8, 2015 12:31 PM
