Sponsored by:
Sponsored by:
one piece drive shaft suggestions
Old Nov 1, 2018 | 10:55 AM
Ponywars's Avatar
been thinking about one for my 2012 gt, been looking mostly at the Steeda aluminum 3.5 inch, anyone using this one or any other brand? SUGGESTIONS
Old Nov 1, 2018 | 11:54 AM
SpectreH's Avatar
Steeda makes good stuff. I bought the Driveshaft Shop carbon one for my car from them. No issues.
Old Nov 1, 2018 | 12:51 PM
Bert's Avatar
I like the one-piece driveshaft because it is an "efficiency" thing - doesn't make the engine produce more power or burn more gas, but more of the power that it is already making gets to the rear wheels. That said, it is not a huge performance difference; rather one of those "hmmmm, I think I might feel a difference" things. Also they do eliminate a lot of the clunking due to slop in the driveshaft, caused by the extra joints in the middle of the factory set-up.
I think the biggest consideration in buying one is whether you want a CV (constant velocity) joint, or not. Some folks say the CV joint is a must, because it eliminates the "phasing" issues that often cause vibrations with the one-piece shafts. On the other hand, the CV joint does add some slop in the system, they do wear out, and I have heard some say they actually added vibration. Also they cost more.
Without the CV joint, you will want to pay attention to the pinion angle; make sure it is set correctly to minimize the vibrations. You might even want to play with it, to find the best spot . . . for that you need an adjustable rear Upper Control Arm.
I'm pretty sure the Steeda does not have the CV joint. I have a Shaftmasters, which also does not have the CV joint. I actually wore out the slip-joint in a shaftmasters shaft, took about 50K? miles. They fixed it up, for a price. Now it is pretty smooth again, though I do get a little bit of vibration under certain conditions, nothing major, and certainly nothing worse than the other noises that my car makes. (2010 with over 100K miles, fairly loud exhaust, and whiney 3.73 gears)
Old Nov 1, 2018 | 01:12 PM
SpectreH's Avatar
My DSS CF unit from Steeda has a CV joint. So far, so good.
Old Nov 1, 2018 | 09:20 PM
EF1's Avatar
EF1
I have had the Steeda 1 piece drive shaft on my 2011 GT for a couple of years now without any issues. It got rid of some of the clunking under the car and does appear to spin up a little faster. I would put a safety loop on the front half of the shaft in case it ever comes loose it won't dig in and act like pole vault under the car.
Old Nov 1, 2018 | 09:38 PM
Ponywars's Avatar
ANY vibration at all under any circumstances, ANY??? Any negatives , ANY???
Old Nov 2, 2018 | 03:25 AM
Bert's Avatar
I would be very surprised if you DON'T have ANY vibration right now; it's only a question of HOW MUCH and does it BOTHER YOU or not
Old Nov 2, 2018 | 08:14 AM
1 Alibi 2's Avatar
www.axle-exchange.com
Had one on my 11, on the advise of my tuner, no issues after 6+ years..
Old Nov 2, 2018 | 10:43 AM
Ponywars's Avatar
thats a 4 inch shaft correct?? i,m lowered 1inch front 1.5 rear any difference in clearance issues between the 3.5 and 4" as far as any problems?any vibrations at all??
Old Nov 3, 2018 | 09:00 AM
1 Alibi 2's Avatar
A 4" shaft.
It's above your exhaust system !!
Metco Motorsports drive shaft safety loop.
No vibration @ all, was installed @ my tuner's shop, along with other mods.
Old Nov 4, 2018 | 11:58 AM
EF1's Avatar
EF1
I didn't pick up any vibrations with the Steeda 3.5" one piece aluminum drive shaft. I did lose a bunch of clunking from underneath from the stock drive shaft.
Old Nov 4, 2018 | 02:08 PM
Ponywars's Avatar
thats the one i have been thinking about going with EF1, NO NEGATIVES AT ALL BROTHER??????????
Old Nov 4, 2018 | 04:05 PM
EF1's Avatar
EF1
None, I installed it about 2 years ago have not had any issues. I track the car when I can and it has held up well and seems to spin up faster than the stock piece. I had one minor install issue with the Steeda drive shaft safety loop impacting something under my car. Luckily I was going by Steeda Valdosta on my way to Sebring. I emailed TJ and he arranged for me to bring it by for them to look at it on my way through. I left the bracket on the car, but removed the loop that was hitting. It took their tech about 5 minutes to see the problem. The safety loop was impacting the heat shield on my MGW shifter. I can't expect them to know fitment of everything they make with every other after market out there, but they shimmed the mounting bracket to eliminate the issue and had me on my way. They said that next time they would know about the MGW issue and could help someone with the same problem over the phone. You can see from the mods in my signature block I like Steeda parts. They make good stuff and stand behind what they sell. They have also been really responsive to questions when they come up.
Old Nov 4, 2018 | 06:01 PM
Ponywars's Avatar
yeah i have steeda stuff also and like it, steeda sport springs,tri axe shifter and bracket g force brace,torque box brace, intake and 93 oct tune, front and rear sway bars, FANTASTIC customer service!! Harry,TJ,Jiggar, everyone i have dealt with nothing but positive results!
Old Nov 5, 2018 | 12:49 PM
Ponywars's Avatar
whats the fastest top end since you ran the shaft was installed?
Old Nov 5, 2018 | 06:35 PM
EF1's Avatar
EF1
Around 130
Old Nov 6, 2018 | 08:19 PM
Ponywars's Avatar
130 and zero vibration, last time i,ll ask you,lol
Old Nov 7, 2018 | 08:05 PM
EF1's Avatar
EF1
Yes no vibration. Maybe mine is balanced better than some, but I don't sense any vibration in mine. Just go ahead and order it already, but I would probably wait until thanksgiving week now. I am sure they will have a sale that week on all Steeda manufactured parts.
Old Nov 7, 2018 | 09:14 PM
Ponywars's Avatar
i,m waiting for the next sale to order along with over axle pipes
Old Nov 13, 2018 | 06:15 PM
Rog13GTCS's Avatar
Looking forward to a review to see how you like it. Steeda should have a Black Friday sale on their parts, if you're leaning their way that will save you some.
Left Lane Muscle
Sep 11, 2016 06:56 PM
firstang001
Feb 13, 2015 11:15 AM
STUKUP2112
May 31, 2014 12:15 PM
muscledom
13
Jun 16, 2012 12:10 PM
PIKE2244
Dec 30, 2009 06:17 AM
