Sponsored by:
Sponsored by:
JPC Budget E85 fuel system install pics 2014 Mustang GT
Old Jan 12, 2016 | 10:50 PM
14stangGT's Avatar
Thought I would post pics and information on installing a return style fuel system. I picked the JPC budget E85 system. Not too bad to install definitely buy the fuel ring tool I show and have a lot of patience.
also ordered MMR OPG and TIMING Gear sprocket and ATI Balancer installing those in a couple of weeks.
bought this on amazon.
remove fuel sensor from factory set up and install it on the new fuel hat
Had to use a 36 inch pipe on the 14 inch breaker bar to seat the fuel ring back
mount fuse / relay module behind seat in trunk
have to loosen k member bolts to get plastic cover out
need a flat blade screwdriver to unclip fuel line from chassis next to fuel tank
mounting fuse blocks on firewall
mounted fuel pump cut off switch to relays to turn off pumps
Set fuel pressure to 56 psi per Justin @ VMP
Over all a great system reasonably priced. Thanks to sam ( cb900f) on svtp for answering a lot of questions along the way.
Old Jan 13, 2016 | 03:09 PM
Blown CS's Avatar
I read this on svt and its a nice right up. I think us fossil fuel guys can even benefit from that set up.
Old Jan 13, 2016 | 04:03 PM
14stangGT's Avatar
Thanks I am not sure it is worth it if you don't go E85 or race fuel. The gas we have in AZ stinks so I could never get the KS off unless I ran 7.5 gallon of SUNCO 108 race gas and then timing only went to 20* adv, with E85 I am 23* - 24*.
I would check with your tuner. Since I am using a 79mm pulley I was running a little lean at higher rpms.
Old Jan 13, 2016 | 06:52 PM
Blown CS's Avatar
I should say for those that want to run a flex fuel tune. I assume your running id1000s which I need to get.
Jim74656
Dec 21, 2015 08:20 AM
Bryan Love
Dec 18, 2015 06:52 AM
Kotenukimen
'10-14 Interior and Audio
Dec 14, 2015 07:24 PM
mark0006
Nov 29, 2015 07:54 PM
