Going sideways on WOT
I just upgraded a few things and got my 2014 Mustang GT tuned. Now from a stop if I apply full throttle my car starts going sideways and 1-2 and 2-3 shifts turn my car almost 45 degrees from the rear end.
I have done a lot of research and it seems upgrading my LCA would help fix this?
Looking for suggestions/advise.
Thanks!
Thanks!
How much power does your car put down? Also what size/compound tires are you using on the back? It's not unusual to loose grip on rear wheels while at WOT. The Coyote is a free revving motor, and quite high on torque output. This generally is not a bad thing (I love going sideways too ).
But if you're trying to harness the power a bit better I would think a beefed up panhard bar and some stickier rubber would help plant the rear axle a bit more.
I like going sideways too, but a controlled sideways. I see other Mustangs with more power accelerate and they grind tires but stay straight.
So LCR would not fix the issue?
One way to stop going sideways is to manage your throttle input... that and get some stickier rubber out back.
Like from a dig, I don't hammer on it until both tires are sticking. If you're going sideways into 3rd gear you must be running a stickier tire upfront or something odd.
TC is on. I don't turn it off much. Would that help?
Stock wheels/tires 18x8 Pirellis
Spam Connoisseur
I got هَبوبed
I got هَبوبed
