Sponsored by:
Sponsored by:
Going sideways on WOT
Old Dec 11, 2013 | 11:09 AM
tormz's Avatar
I just upgraded a few things and got my 2014 Mustang GT tuned. Now from a stop if I apply full throttle my car starts going sideways and 1-2 and 2-3 shifts turn my car almost 45 degrees from the rear end.
I have done a lot of research and it seems upgrading my LCA would help fix this?
Looking for suggestions/advise.
Thanks!
Old Dec 11, 2013 | 11:25 AM
ShaneGT's Avatar
whats the issue??
Old Dec 11, 2013 | 11:28 AM
5.M0NSTER's Avatar
How much power does your car put down? Also what size/compound tires are you using on the back? It's not unusual to loose grip on rear wheels while at WOT. The Coyote is a free revving motor, and quite high on torque output. This generally is not a bad thing (I love going sideways too ).
But if you're trying to harness the power a bit better I would think a beefed up panhard bar and some stickier rubber would help plant the rear axle a bit more.
AlsCobra's Avatar
A Man Just Needs Some....
Better tires helps too. The geometry of the rear end as it squats will slightly shift the rear end. I would try better tires first.
Old Dec 11, 2013 | 11:33 AM
wheelman's Avatar
Originally Posted by ShaneGT
whats the issue??
Lol, exactly!
Old Dec 11, 2013 | 11:53 AM
tormz's Avatar
I am going tomorrow for a few dyno pulls and will know for sure. Estimated around 450-460 with my mods and similar setups.
I like going sideways too, but a controlled sideways. I see other Mustangs with more power accelerate and they grind tires but stay straight.
So LCR would not fix the issue?
Old Dec 11, 2013 | 12:02 PM
Just to get the no brainer out of the way, TC is off right?
Old Dec 11, 2013 | 01:42 PM
Krohn's Avatar
One way to stop going sideways is to manage your throttle input... that and get some stickier rubber out back.
Like from a dig, I don't hammer on it until both tires are sticking. If you're going sideways into 3rd gear you must be running a stickier tire upfront or something odd.
Old Dec 11, 2013 | 01:59 PM
tormz's Avatar
TC is on. I don't turn it off much. Would that help?
Stock wheels/tires 18x8 Pirellis
Old Dec 11, 2013 | 02:06 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
Old Dec 11, 2013 | 02:09 PM
Bocefus's Avatar
Don't smash the throttle till u have traction. Or just get slicks
Old Dec 11, 2013 | 02:29 PM
GrabberBlue5.0's Avatar
Doubtful.
And you need a better tire.
Old Dec 11, 2013 | 02:41 PM
tormz's Avatar
Originally Posted by GrabberBlue5.0
Doubtful.
Agreed on the tires!
Old Dec 11, 2013 | 02:57 PM
You want to hook? This is what you need.
Old Dec 11, 2013 | 03:00 PM
Yes! Always turn it off before an aggressive take off. You're probably spinning the tires. The ECU is applying brakes because it thinks you're spinning in snow/ice.
Old Dec 11, 2013 | 03:07 PM
tormz's Avatar
Attached Thumbnails Going sideways on WOT-1002916_10202556223730265_222909832_n.jpg
Old Dec 11, 2013 | 03:08 PM
tormz's Avatar
I figured TC would make the tire spin much worse.
Shows what I know.
Old Dec 11, 2013 | 03:10 PM
tormz's Avatar
What is your tire/wheel setup?
Old Dec 11, 2013 | 03:13 PM
Shows what I know.
It momentarily adds braking on and off to the wheel it detects spinning, hoping that pause will regain stickiness to the surface.
When you have TC off it looks like this:
Old Dec 11, 2013 | 03:27 PM
Weld RT-S wheels. 17x4.5 up front with a Hoosier front radial skinny and 15x10 out back with a M/T 295/55-15 drag radial.
