Sponsored by:
Sponsored by:
Which clutch do I want/need?
Old Jun 26, 2014 | 03:32 PM
Gabe's Avatar
Car is a '13 5.0 pushing 10psi via a 2.3L Whipple, 3.73 Torsen out back.
I'm looking at the McLeod RST or the RXT, but the RXT seems like overkill, at least for now.
I'd like to keep the stock flywheel, if only for the lack of the added expense.
How good is the RST with the stock flywheel?
Does any of the driveline clunking go away with an aftermarket clutch?
And what else would I need to buy, to swap out the clutch?
Thanks guys.
Old Jun 30, 2014 | 09:33 PM
shayner's Avatar
Driveline clunking?
Sounds like you have a drive shaft issue.
Old Jul 3, 2014 | 06:17 PM
Tapakegovagnaps's Avatar
I have the identical setup and I'm also wondering what clutch will suit me best. Doesn't look like any advice will be found here....
Old Jul 4, 2014 | 11:04 AM
sclv12's Avatar
Originally Posted by Gabe
Car is a '13 5.0 pushing 10psi via a 2.3L Whipple, 3.73 Torsen out back. I'm looking at the McLeod RST or the RXT, but the RXT seems like overkill, at least for now. I'd like to keep the stock flywheel, if only for the lack of the added expense. How good is the RST with the stock flywheel? Does any of the driveline clunking go away with an aftermarket clutch? And what else would I need to buy, to swap out the clutch? Thanks guys.
How much HP are you making with the whipple? How much that cost?
Old Jul 5, 2014 | 03:34 AM
Jay@Hypermotive's Avatar
Former Vendor
Gabe, clutch fluid and line is key.
RST should, in all theory, be fine. I've heard stories of guys destroying their RST clutches at your power levels in a short period of time but something tells me they were either at the drag strip every weekend or they need to practice driving a manual.
Slave cylinder and throwout bearing as well. Hope this helps.
Old Jul 5, 2014 | 05:50 AM
AlsCobra's Avatar
A Man Just Needs Some....
I had a Spec 3+ on mine that did very well. Like others have said, the fluid and lines along with the slave/TOB just kinda suck. I would look into upgrading those.
Old Jul 5, 2014 | 03:59 PM
Gabe's Avatar
Well, gonna need to do something very soon.
Did 12 Autocross runs today and the last couple of runs provided me with some nice burnt-brake/clutch-fluid smell at the end.
So, while the autocross itself was a blast (videos will be up later tonight or tomorrow ), it certainly told me that my car needs something else VERY soon.
Old Jul 6, 2014 | 08:14 AM
Former Vendor
How'd the Whipple handle with that many runs?
Old Jul 6, 2014 | 07:05 PM
Gabe's Avatar
very well, no issues other than the clutch smell or whatever that smell was.
Plus, I need better front tires next time.
Old Jul 6, 2014 | 07:06 PM
Gabe's Avatar
Which brake fluid do I want?
Looking at the Amsoil Dot 3 or Dot 4, but the Dot 4 says to be replaced every 2 years
Old Jul 6, 2014 | 08:43 PM
5.M0NSTER's Avatar
Some of the guys on here (including myself) use Motul RBF600. Raises dry boiling point to ~593 deg F. It's full synthetic DOT 4. I haven't heard anyone having issues with it yet. I do track weekends at road courses.
Old Jul 7, 2014 | 06:43 AM
Gabe's Avatar
Thanks, just checked into it, and I found that it should be replaced once a year though ... the Amsoil says every 2 years, and it has a boiling point of 580, close enough for me ... just ordered 3 bottles of Amsoil Dot 4.
Also gonna look into the stainless steel brake lines ... replacing those should certainly make flushing the brake fluid EASY, lol
Old Jul 8, 2014 | 10:46 AM
Former Vendor
I had to replace the Motul every 3 months, depending on track days of competitiveness after a weekend.
Good stuff though
Old Jul 8, 2014 | 05:35 PM
5.M0NSTER's Avatar
Good stuff though
Wow, that's quick. Their instructions tell you to bleed with fresh fluid before every race for best results though. I plan on keeping mine in there for at least a year. I did my first track weekend on stock brake fluid with 4000 miles on the car with no change in pedal feel (but solid pads). But now that the fluid was a year old I replaced it with Motul.
Do you have any experiences with other fluids?
Old Jul 15, 2014 | 12:07 PM
PaxtonShelby's Avatar
Go with the RXT. The RST simply is not made for any drag use. You can smoke it in a heartbeat. For the few extra hundred $$ the RXT is as stout as it gets, all while giving you great driveability. That's why I went with the RXT in my 1966.
Old Aug 13, 2014 | 03:50 PM
sclv12's Avatar
How many bottles does it take to flush the brake system?
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
