CDC-type Grille while retaining 13/14 GT Fogs
Anyone managed to accomplish this?
I'd like a meaner-looking grille, but I don't want to lose or relocate the led fogs in the grille.
Anyone know of, or has fabricated a CDC-type grille with the factory fogs in place? I have trawled the interwebs to no avail...
Make a bracket that mounts to the frame & positions the lights deep in the grill. I've seen people that have mounted them behind grills. Just find out what they did to mount them.
I thought about mounting halos this way but never got around to it. Wouldn't be too hard and I'm holding off since inn looking for another stang.
There's a guy on eBay that sells the relocation brackets to hide the fogs behind a billet grille. You could most likely use those, but again you'd want to hide them behind a mesh. They'd be out in the open and the lights themselves are unfinished - I thought about doing something similar when I had a CDC grille, but scrapped the project. The only way I could see it looking good with the CDC grille is if you use some other round lights that a) fit the opening better and b) are meant to be exposed. The factory lights are not meant to be exposed - you see the LED heat sinks and there's no finisher trim around them, so they'd throw light all over the place.
Only issue would be how durable the halos would be since they wouldn't be inside a housing.
ppdstang15
12/25/15 09:19 AM
11/24/15 08:01 PM
