Boss intake manifold and the evil of emissions
Would that change if you were making power adder type power- yes more than likely... That is not my situation at the moment so in the interim, the gears are winning. I will re-gear the car if and when necessary, no big deal
Can I just throw a wrench into the equasion here??
Why do you want the Boss manifold? Unless something has changed in the past year or so, the conventional wisdom was that unless you had a built bottom end that could take advantage of ~7500 RPM, the Boss manifold is only going to slow you down.
Remember that the Boss has different rods, pistons crank(?) valuetrain, etc. that allow the motor to rev higher and benefit from that intake.
Just playing the devil's advocate...
Ported boss the lowdown losses are pretty much erased. If you can detect any slowness from a correctly installed and ported boss installation then your butt dyno is probably more sensitive than Superflow's best offerings, LOL
edit: 1/2 the people reporting their junk was slower with a boss were running an unported one, with the mismatched halves, no cleanup work, and no cares given during install... My guess is those probably did run like crap...
See my response in the other thread. The 4.10's are quicker, period.
Would that change if you were making power adder type power- yes more than likely... That is not my situation at the moment so in the interim, the gears are winning. I will re-gear the car if and when necessary, no big deal![Wink](https://themustangsource.com/forums/images/smilies/wink.gif)
![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
