Boss 302S Intake Manifold
I installed the intake manifold without a hitch, but the engine light comes on.
Ok, so the DTC code is P0443, evaporative emission system purge control valve!? I reconnected everything, so why would this be coming on?
Was able to clear the DTC, went a full day without the light and it came back on each time after I start!
Yes, SCT3 with 93 tune from Stage 3 (allegedly)! I gave them all the numbers and parameters, but is been doing it since the tune and I feel there should be better response than what I'm getting!
The purge valve is the one that must be relocated... Pain in the ****. Are you sure it's reconnected completely and correctly and relocated some where safe?
Yeah, it's located on the back of the manifold. I had to extend the wires from the stock location down the right side of the manifold to the rear. It's plugged in all the way. I believe I used 14 or 16 ga wire.
Well, you know about assumptions, and there weren't any instructions with the kit. However, I found the two wires from stock location, cut and added wire to the new location!
