Sponsored by:
Sponsored by:
Aluminum drive shaft, anyone?
Old May 4, 2011 | 09:47 AM
MRGTX's Avatar
It seems like the 4.6L guys are more interested in a driveshaft upgrade than the 5.0 guys...
Still, lighter weight, less rotating mass, stronger, etc... sounds like a great mod.
Has anyone installed one yet? Is it worth the hefty price tag?
http://www.brenspeed.com/2011-mustan...riveshaft.html
Old May 4, 2011 | 01:45 PM
CO_VaporGT_09's Avatar
It's cause we're trying to keep up with y'all!
I got the Shaftmasters, great quality, great name (they send you a T shirt, don't know if I'd ever wear it, but the wife in it is rather funny). Immediate, noticeable difference from the first take off.
Cheaper than the Dynatech, too, $625:
http://shaftmasters.com/3aldrfomu20v6.html
Old May 4, 2011 | 03:09 PM
dan_h's Avatar
I dont have one in my 2012 but i did in my 2006 GT ... dont know how effective it was since i did it at the same time as a gear change to 4:10s...but, i can tell you that it will be louder (NVH-wise) inside the cabin.
Old May 4, 2011 | 05:20 PM
I haven't noticed that at all. Theoretically it should be quieter, has one less bearing and connection to the car, and its connections are damped through the rear end and engine bushings.
Old May 4, 2011 | 08:07 PM
dan_h's Avatar
From a technology perspective if you study the stock 2 piece unit you can appreciate the thought that went into it's design...two unequal length pieces w/isolators ~ midway through it's length...well designed for resonate frequency mitigation. And noise loves to travel down long straight pipes, like a 1 piece unit! However, the 2 piece is also a heavy beast....which is why i chunked it for the 1 piece! . I'm sure it helped, but man, the switch to 4:10s really made for a different driving experience (I had 3:55s stock) so i couldnt tell how much the driveshaft (alone) contributed. I know this...i could spin up my tires 'really fast'
Old May 4, 2011 | 08:45 PM
908ssp's Avatar
Check out the PST drive shaft a smarter design. They are made in aluminum and carbon.
http://www.svtperformance.com/forums...t-install.html
Old May 4, 2011 | 09:10 PM
Very cool looking and sounds impressive, but way pricey, $1100+
Old May 4, 2011 | 09:12 PM
AlsCobra's Avatar
A Man Just Needs Some....
Bang for the buck NO. Probably could have one custom made for less.
Old May 5, 2011 | 07:07 PM
wproctor411's Avatar
I would like to get one. We put one on my buddies 5.0 and it was feather weight. After the suspension mods I am doing Clutch, Flywheel, Aluminum Driveshaft and Safety loop. Are any 5.0 K-members available? Will the BBR K-Member work with different motor mounts?
Old May 6, 2011 | 04:18 AM
FCMalie's Avatar
I plan on getting one eventually, but it's one of those staged mods because I probably plan on swapping the trans when I go FI. I know the MT82 has held up in FI situations I just don't like it barely being rated high enough for stock torque on the 5.0. So yea, tranny and 1 piece drive shaft at some point, but not for a few years.
Old May 6, 2011 | 07:32 AM
Looks like these CF ones are semi-custom, you have to actually measure your tranny to differential length, there's no slip-yoke so no one size fits all.
Old May 7, 2011 | 04:25 AM
So its just like ordering one for a 4x4. That is interesting but kind of typical for driveshafts outside the stang world.
dblhelx
Oct 6, 2015 08:08 PM
FromZto5
75
Oct 5, 2015 02:27 PM
oldnjguy
Sep 10, 2015 02:39 PM
