Sponsored by:
Sponsored by:
2013 GT Hood Vent Cold Air Intake Water Test
Old Oct 26, 2012 | 01:06 PM
RCE EATR's Avatar
Lightbulb 2013 GT Hood Vent Cold Air Intake Water Test
Did a worst case scenario test of the hood vents and whether they allow much water ot get on the filter of a cai. Again this is worst case scenario though, simulating if you were to be stopped in heavy rain with wind blowing rain in the vents somewhat.
Should be fine with a little water though, takes a good amount of water to hydrolock an engine. With the filter there and water able to drain out from around it, there shouldn't be issues with it getting submerged in water and causing issues. Interesting results though.
Old Oct 26, 2012 | 10:04 PM
BluehazeGT's Avatar
Hey w8tlifter, great video. I was surprised just how much water does get in. Like you said though your test was probably a little more extreme than you would typically see.
You have created a great set of videos. Very helpful thanks
Old Oct 27, 2012 | 06:15 AM
RCE EATR's Avatar
thanks I appreciate it!
I'll probably be getting this http://www.autoanything.com/air-filt...A2582A0A0.aspx in black to help repel any water.
Old Oct 27, 2012 | 06:30 AM
SINBUSTER007's Avatar
first, i think this was a dumb move by ford, not taking into consideration where the water goes from the vent. its a cool idea for the vents in the hood.
my suggestion would be: 1. either dont drive it at all in the rain or 2. if you suspect rain then cover that particular vent with either blue painters tape or roadwrap. both will not hurt the paint and will keep the water out.
since i do not have a 13 (i have a 12 without vents) i would wonder what the affect would be with completely sealing off the openings in the vents, so they are "dummy" vents? since its the same engine from the 12 and we dont have vents then the changes should be minimal correct?
Old Oct 27, 2012 | 08:06 AM
dleblancbu's Avatar
Um, I may be missing something here, but the factory cold air intake shields the filter for just this reason, among others. Aftermarket cai leave the filter exposed, and from what i've read in others doing testing of the aftermarket intakes, they make little if any difference in power. Am I wrong?
Old Oct 27, 2012 | 08:21 AM
jayman33's Avatar
Individuals who buy mustangs and are enthusiasts dont but one to leave stock. Ford should have recognized that. Look at just about and blower and the filter is relatively close to the vent. Just saying.
Old Oct 27, 2012 | 09:44 AM
GrabberBlue5.0's Avatar
You are correct. Too many try to reinvent the wheel. The car came with a CAI from the factory.
Old Oct 27, 2012 | 09:49 AM
Stevedotmil's Avatar
I think I saw some of the newer CAI shields that have the extra on the top to keep the water off the filter for the 2013.
Old Oct 27, 2012 | 12:26 PM
mikeyt03's Avatar
This will fix the problem. I ordered the fiberglass version for 599. It has functional heat vents as well, they are just hidden.
Old Oct 28, 2012 | 05:10 AM
RCE EATR's Avatar
Niiiice
Old Oct 30, 2012 | 08:22 AM
SteedaBrandon's Avatar
Former Vendor
OP, thanks for posting. We have done testing on our own 2013s through various conditions (normal driving, stop lights, etc. through Florida rainstorms) with no issues. We have done parked water intrusion tests where we sprayed the vents and we didn't see anywhere near the water intrusion that you have shown in your video, and I suspect it's due to the angle that you were spraying the water and the pressure. As such, it's very unlikely to have that much water intrusion driving in a typical rainstorm, probably the only time you would maybe see that would be if you were driving in a hurricane or something.
Yes.
I have attached a dyno sheet that was a test we did about a year and a half ago of the stock airbox vs the cold air.
On this test the car was loaded with a basic tune with no cam timing changes just so we could have a higher rev limiter that way we could rev the engine to the same RPM with both intakes without running into a limiter. Ignition timing was the same for both tunes.
The results show a “peak” gain of only 5 horsepower, but there is a lot more there if you read the dyno sheet. Gains started at about 4,500, with gains of 6 to 9 horsepower between 4,500 and 5,000. Between 5,300 and 6,100 gains were 7 to 10 horsepower. And between 6,700 and 7,200 the gains were an impressive 12 to 15 horsepower. So you can see measurable gains from a cold air intake.
Old Oct 30, 2012 | 09:40 AM
Doug@C&L's Avatar
We at C&L have accepted this as an issue from day 1 and even have a customer with a different NAME brand air intake that hydro locked his engine and had to replace the throttle body, intake manifold and one head NOT under warranty.
Our 2013 GT kits come with the proper shielding to prevent this from happening to you.
On a small side note, in the video you can see how wet that shop towel got, especially when it was rung out. When the water hits the filter it will do the same and soak it up like a sponge, then allow it through.
As for Water/Meth Injection you are correct it is injected into the engine, but with a Metered amount, kind like nitrous, at specific times. I've tuned and actually designed water injection kits for the X-charger V6 supercharger system for 05-10 mustangs. One thing I found was that too much water would hurt performance and even eat the protective coating off the supercharger rotors, this was with a .032 sized Jet with 100-125 psi of water pressure, much smaller then a rain drop. The water burns to help keep the intake charge cooler but too much water puts out the spark kernel and water doesn't compress like air.
Thanks, Doug
Old Oct 30, 2012 | 11:26 AM
RCE EATR's Avatar
yeah thats why I said it was basically a worst case scenario example lol.
Thanks, Doug
Hmm very interesting. Thanks for posting Doug! I'll likely be getting an injen hydro shield to help protect the filter.
Old Oct 30, 2012 | 07:51 PM
RoushGrabberBlue's Avatar
Thanks, Doug
Thanks for making a great product that addresses this issue, keep up the good work!
jonser
Ecoboost
Aug 30, 2015 11:47 AM
jlaval05
Aug 27, 2015 10:08 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Ecoboost
Jul 25, 2015 06:32 PM
