Panhard bar install question 2010
Sorry if this is a stupid question. I have an adjustable bar from BMR and was wondering if I can use my ramps to raise the rear up (I don't have a floor jack).
This isn't clearly explained in the instructions. If I must use jack stands, where do I position them? I have little understanding how the suspension works. Thanks for any input.
Unless something's changed on the 2010, your best bet is just doing it on the ground. If you're trying to center your axle, do it with the wheels on the ground or ramps with the suspension under load. It's a really easy project, I used ramps, no need for a jack.
ustabawannab
8/5/15 08:32 PM
