'10-14 Special Editions and Aftermarket Mustangs
Glass Roof Pros/Cons?
Old Apr 9, 2010 | 01:00 PM
  #41
eci's Avatar
eci
Originally Posted by ipodintampa
I would think that if you plan to track your car, and really modify it then the glass roof isn't a great idea. Especially if you modify the car, supercharge or nitrous it, and it goes over 500hp. There is a degree of flex, and metal bends slightly and twists. Glass doesn't.
I haven't seen any glass roof cars go to the track and run a 1/4 mile yet for some reason. I was just in Bradenton this year at the NMRA Ford Nationals. Hardtop or Convertible with Roll Cages. Glass Roofs are more of a luxury, driving experience, although they are nice for letting ambient light in your vehicle and on pretty days.
Another concern would be leakage. What happens if you spring a leak in a corner due to chassis flex? I don't know if it's possible on a stocker, but throw a Whipple and some boost- and let'r rip and see what happens....
I myself am still on the fence with a glass roof. I like it, but part of me doesn't. It's nice for my kids in the rear seat to look up and out- and is something different. But for taking it to the track, or if you ever roll your car- I wouldn't want a sharp piece of glass stickin in my head or through my neck...
my .02
Disagree. Glassback is available in the 550HP 2011 GT500 even WITH the SVT Performance Package. Ford knows **** well these cars are pushed past 800HP and have the **** driven out of them.
Old Apr 9, 2010 | 02:21 PM
  #42
ipodintampa's Avatar
Question
I appreciate your feedback.
Let me ask another good question regarding Glass Roofs--
When it gets hot outside and sun is beaming down, does it help repel heat, or contain it? Another words, is it hotter inside than a Metal Roofed Coupe, or Cooler? I am so curious about this, because I live in Florida where it gets pretty HOT outside, and was wondering if this is an issue.....???
Is it a big magnifying lens? Or does it filter and keep out heat pretty well?? I was hoping to hear this from people who own them, or know good data to support....
Thanks in advance
Old Apr 9, 2010 | 02:45 PM
  #43
stangfoeva's Avatar
MOTM Committee Member
didn't someone do a test and discovered it was only a few (1-3) degrees warmer than the regular coupe? The glass is tinted, they realize you'd be cooked alive otherwise....
Old Apr 25, 2010 | 07:25 PM
  #44
lavalamp27's Avatar
I am debating changing my order and adding this glass roof and I had a question. Does the glass roof decrease the head room at all?
Old Apr 29, 2010 | 09:51 AM
  #45
montreal ponies's Avatar
Nope, i don't think it changes headroom at all, and after reading this thread last night and doing some thinking, i decided to change my order and add the glass roof. Initially i wanted to get a vert but decided to go with a coupe. I feel like the glass roof is a nice compromise between coupe and vert. I'm sure i won't regret my choice.
Old Apr 29, 2010 | 10:27 AM
  #46
xlover's Avatar
that is going to be a good looking stang, sterling with the brembo wheels is real good and the dark roof from the glass tint will be real nasty... plenty of picks when you get it
Old Oct 12, 2010 | 01:09 AM
  #47
Digital_Synapse's Avatar
I didn't get the glass roof option, but now I wish I had.
Old Oct 12, 2010 | 11:07 AM
  #48
CO_VaporGT_09's Avatar
GlassRoof on the track, leaking and flopping over...
If only someone had told me I couldn't track the car with that leaky, heavy, hot glass roof on there. Then my car wouldn't have soaked me, baked me, and flopped over on the side as I went around the corner...
Universally it is the one feature every one loves most about my car. The shade works very well and cutting down the glare but does little for the heat as it's not a problem in the first place. The shade does take away head room, but I'm 6'1" and just make sure the seat isn't all the way up high. The helmet's not a problem, either. And the glass is stiffer than the flimsy steel roof, but admittedly heavier and higher CG, but my 200+ lbs doesn't help there, either. I do believe if I turn it into an American Iron racer (which I might in a few years) I might have to pull it out and weld in a standard steel roof, but don't quote me on that.
In summary, get the thing, it's totally worth it
(warning, picture whoring below)
Old Oct 12, 2010 | 11:39 AM
  #49
2BlownStangs's Avatar
great looking car CO VaporGT. I have enjoyed my glass roof on my Saleen for over 3 years now and wouldn't trade it for anything.
Old Oct 12, 2010 | 12:00 PM
  #50
stangfoeva's Avatar
Glass roof FTW
Old Oct 14, 2010 | 11:56 AM
  #51
erickburke's Avatar
I'd be willing to bet that the glass roof is much stiffer than the standard roof.
Think about it! The glass is thicker and more rigid than the thin sheet metal.
I've seen an install of the CDC GlassBack and the internal structure between the glass & metal are identical.
Old Oct 15, 2010 | 07:37 AM
  #52
Also there's structural adhesive used around the entire perimeter. Assuming that holds up, there should be much less flex than standard body-thickness sheetmetal
Old Oct 17, 2010 | 12:08 PM
  #53
big_ole_truck's Avatar
If you are talking about engineering properties of either choice, you need to consider shear resistance and flexural torsional resistance of the glass versus the metal roof. Using glass as a stiffening member is always a possibility but then you'll need more thickness (and weight) than a thin guage sheet metal roof capable of resisting the same torsion and shear.
In the end, it comes down to personal preference. I can understand why consumers would love the fixed glass roof.
Old Oct 17, 2010 | 12:34 PM
  #54
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
pro
if somone was pooping on your roof you would know.
con
if someone was angry with you they could hit it with a rock.
Old Oct 17, 2010 | 08:45 PM
  #55
pro
con
Now that's just plain funny ...
Does make me wonder, cheaper to replace a heavily dented steel roof, I'd suppose, than the glass, wouldn't you think? How would the steel roof be replaced anyhow, cut out?
Old Mar 27, 2012 | 08:43 AM
  #56
psjmd's Avatar
Does the glass roof affect the sound quality of a high-end stereo ???
Old Mar 27, 2012 | 09:25 AM
  #57
Automagically's Avatar
Glass is a more solid medium. It will help with internal dampening. Though you no longer have a roof liner so in many cases it's negotiable. But glass roof should sound pretty solid.
Old Apr 6, 2012 | 06:51 PM
  #58
Laroh's Avatar
I'm getting it on my next 2015 for sure.
Old May 8, 2012 | 10:38 AM
  #59
MonsterCat's Avatar
The Lincoln MKZ is going to have a retractable glass roof as an option. I wish this was available on the Mustang, from Ford vs after market.
The following link shows the refit, with a video of the retractable glass in operation.
The 2013 Mustang GT I have on order will be my wife daily summer driver which is a no go in the snow up here. So, she gets to drive a 2004 Expedition 5 months a year.
After looking at this new Lincoln's roof, My Red Cat (bright Red Jag x-type) may need to become a Lincoln next year. I like an all-wheel drive sedan for a year round daily driver, and won't put myself in an Audi.
http://www.autoblog.com/2012/04/02/2...or-production/
Old May 9, 2012 | 01:35 PM
  #60
Resolution78's Avatar
is there anyway to backfit this into a 2012 that you already own ????
