What that fuse is responsible for?
Old Jan 7, 2009 | 03:13 PM
seabiscuit's Avatar
Any one have idea what that fuse is responsible for? And where to buy that in some Internet shop?
Old Jan 7, 2009 | 06:05 PM
J2L06GT's Avatar
Thats not a fuse, its a mini relay,
according to manual its for Accessory delay #1.
What problems are you having that makes you
think that is bad.
Old Jan 7, 2009 | 11:54 PM
seabiscuit's Avatar
think that is bad.
Ok that is a bit complicated but here we go:
I have no original US turn lights signals on the rear - power is dead- and front ones are blinking quick. I am in Europe so I have to have like Canada pattern - independent turn signal not connected with stop light on rear. I could not get over the lost power so I take the signal from the front ones to the rear. This way I got turn signals all around but they hyper flash. I have check all fuses and all are good so I was guessing that 'mini relay' is responsible maybe for the turn signals on the back and something is wrong with that. All turn signals are going to SJB.
If I will get back the power to original turn signal wires I would install there resistors to imitate bulbs to stop hyper flashing. But there is no power. All other fuses are good.
I am in Poland Europe so I can not go to Ford Dealer to fix it up – I have to fix it up my self. I can buy that – mini relay as probably it is not expensive piece – but again I can do that only in some web shop as I can not go to Ford dealer/service.
Anyway before buy would be nice to know what that mini relay control?
Do you know maybe some online Ford help phone where I could phone and ask them what it is for?
Old Jan 8, 2009 | 05:31 AM
05YellowGT's Avatar
If one of the bulbs burns out the other lights fast as a warning , so it may not have anything to do with the relay. Try replacing the rear bulb that you say is out first ...
Old Jan 8, 2009 | 06:20 AM
seabiscuit's Avatar
I said that original wires/bulbs are cut off and there is no power in them now - just disappeared.
Cut off because of changing pattern to European regulations.
I can not put bulb or resistor to imitate the bulb as there is no power. Something is wrong in SJB but all fuses are ok so I thing that this mini relay can be broke but not sure as I can not find any where what is it responsible for.
Old Jan 8, 2009 | 09:09 AM
J2L06GT's Avatar
That relay should not cause the problem you have,
only keeps power on assc after key is off for short time.
In this forum do a search for "tail light wiring diagram"
it shows how they were originally wired, may have a
ground wire cut that should not have been.
Old Jan 8, 2009 | 10:33 AM
Try the bulb first, then if that doesn't work pull the taillight buckets and check the wires for a short. I had accidentally shorted mine trying to install the sequential tail lights. I managed to wrap the wire around one of the screws that hold it in.
papayote
Ecoboost
Feb 21, 2017 11:16 PM
Fastnloud
Feb 15, 2016 05:21 PM
Fedupdave42169
Oct 23, 2015 09:58 AM
tang65c
Oct 6, 2015 07:39 PM
samjluck
Sep 17, 2015 10:24 PM
