What is this engine sound?
Old Apr 12, 2011 | 08:25 PM
mustangspeeder's Avatar
It started happening a couple weeks ago, I notice it most at idle because I can't hear it over my exhaust when driving.
It increases with rpm.
Pressing the clutch down has no effect on the sound, it is constant.
http://www.youtube.com/watch?v=m3aea7_qi_U
Old Apr 12, 2011 | 09:01 PM
05stangkc's Avatar
VCT SENSOR. My first guess.
Does it Crank Hard. As in the engine seems to fight itself to turn over?
File Type: pdf
Old Apr 13, 2011 | 05:42 PM
slidejob's Avatar
Get a long screw driver or some kind of steel rod & use it to isolate the noise. One end on the engine the other on your ear. Hunt down the noise. Hard to tell, but could be a lifter is collapsed & you are hearing the rocker making noise. Be careful, you can suck a valve if that rocker gets jammed between the cam lobe & valve spring.
redrock35
05-09 Exterior Modifications
Jul 31, 2016 08:50 PM
Evil_Capri
Aug 27, 2015 01:08 PM
Mackitude
Aug 13, 2015 01:05 PM
EaterofWorlds
Aug 9, 2015 06:01 PM
MicroSprint5
Jul 15, 2015 11:03 PM
