TAK TAK TAK noise for the drivers side of the motor
Old Apr 24, 2008 | 01:45 PM
Pendarus's Avatar
When cold my 2005 GT auto makes a continuous TAK TAK TAK noise that varies with RPM's. As it warms up it goes away, but lately it is getting louder and lasts longer. Also the exhaust note is deeper and louder untill the noise goes away. After it stops the car is quiet and purrs like a kitten.
I am assuming it is valvetrain noise. Is this normal? It only sounds like it is coming from the drivers side of the motor.
Thanks!
Old Apr 24, 2008 | 04:15 PM
frdtch05gt's Avatar
That is most likely either a stuck/collapsed valve lash adjuster, or a faulty VCT solenoid. Use a mechanic's stethoscope or listen through the handle of a long screwdriver. Put it on the valve cover of the side you suspect the problem is coming from.
Old May 1, 2008 | 09:38 AM
07gtcs's Avatar
Bring it down here to the great mechanics of Florida and they'll tell you it's totally normal because it is a high performance engine...
RRRoamer
Jan 19, 2017 05:27 PM
radio
Sep 17, 2016 03:37 PM
JonsMustang
Mar 5, 2016 05:44 PM
dave07
Oct 4, 2015 06:07 PM
poldrv
Aug 18, 2015 06:42 AM
