Shifting Very Notchy Tsb Soon???
How many of you feel like the shifting is really notchy and sometimes imposible to get into gear when shifting at higher rpms ?? I brought my car in and they said it was normal. I then asked them if I could compair the shifting with a new car. With the car off I could feel the difference. They said they didn't notice. I then said they were on crack. Is dealership staff trained to BS the customer to save labor?? I know there isn't a recall or TSB. BUT THERE SHOULD BE ONE. THIS IS CrAzY !!!
Shouldn't be hard to shift though, mine's smooth as glass and I have never missed a shift.
problem getting worse
It seems that the problem is getting worse everyday. i'm taking it back in and having the service manager compair the shifting on my car with a new one. I developed a new problem. When downshifting to first around 8-10 mph , there is a small grind before engaging. looks like I might have to call Detroit to get my problem solved
Hmm, sometimes I feel a little grind. But it's always my fault: either I didn't FULLY depress the clutch pedal or I didn't rev-match, and my synchros needed some time to catch up, causing gears turning at different speeds to touch (that's what I imagine is happening.. is that even possible?).
Probably has something out of alignment or it could just be a tiny defect in one part causing a problem. I would think they would just put an entirely new shifter unit in. The 07's and up are pretty snickity-snick and clean shifting for a stock unit if all is well.
Having them compare one should make it quite obvious if there is an issue. They changed the shifter a little bit for 07, so there may be a TSB somewhere in the mix??
Gigantor
5/11/23 07:31 PM
