Shifting Very Notchy Tsb Soon???
Old Aug 28, 2007 | 05:45 PM
2006muzzy's Avatar
How many of you feel like the shifting is really notchy and sometimes imposible to get into gear when shifting at higher rpms ?? I brought my car in and they said it was normal. I then asked them if I could compair the shifting with a new car. With the car off I could feel the difference. They said they didn't notice. I then said they were on crack. Is dealership staff trained to BS the customer to save labor?? I know there isn't a recall or TSB. BUT THERE SHOULD BE ONE. THIS IS CrAzY !!!
Old Aug 28, 2007 | 06:09 PM
MustangRetribution's Avatar
I havent had any issues, well none I could blame on the manufacturer
Old Aug 30, 2007 | 01:24 PM
kevinb120's Avatar
They are trained to make money i.e. more labor = more money.
Shouldn't be hard to shift though, mine's smooth as glass and I have never missed a shift.
Old Aug 30, 2007 | 04:30 PM
davisinla's Avatar
Smooth shifter here...although I can't say the same for the clutch engagement - that seems to have bit of slop.
Old Sep 3, 2007 | 10:32 PM
ov3n's Avatar
I have the same issues you describe, Muzzy.
Old Sep 4, 2007 | 08:42 PM
2006muzzy's Avatar
problem getting worse
It seems that the problem is getting worse everyday. i'm taking it back in and having the service manager compair the shifting on my car with a new one. I developed a new problem. When downshifting to first around 8-10 mph , there is a small grind before engaging. looks like I might have to call Detroit to get my problem solved
Old Sep 5, 2007 | 11:24 AM
ov3n's Avatar
hmm mine never grinds, but sometimes it feels 'crunchy'....
Old Sep 5, 2007 | 12:04 PM
krnpimpsta's Avatar
Hmm, sometimes I feel a little grind. But it's always my fault: either I didn't FULLY depress the clutch pedal or I didn't rev-match, and my synchros needed some time to catch up, causing gears turning at different speeds to touch (that's what I imagine is happening.. is that even possible?).
Old Sep 6, 2007 | 03:36 AM
ov3n's Avatar
gears are always engaged - its the synchros and various selectors that are actually grinding.
Old Sep 6, 2007 | 06:33 PM
kevinb120's Avatar
Probably has something out of alignment or it could just be a tiny defect in one part causing a problem. I would think they would just put an entirely new shifter unit in. The 07's and up are pretty snickity-snick and clean shifting for a stock unit if all is well.
Having them compare one should make it quite obvious if there is an issue. They changed the shifter a little bit for 07, so there may be a TSB somewhere in the mix??
Old Sep 6, 2007 | 06:48 PM
krnpimpsta's Avatar
Ahh.. my poor synchros.
Old Sep 7, 2007 | 04:38 PM
2006muzzy's Avatar
thanks for the advice
Old Sep 20, 2007 | 07:05 AM
imyy4u's Avatar
the reason that happens is because it is supposed to! our mustangs have a first gear lockout feature to prevent accidentally shifting into 1st at high speeds and blowing the engine. you must be fully stopped, or going less than 3-5mph to shift into 1st gear. it is a safety feature, and by forcing it, you are destroying the transmission!!!
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
