S-197 Spark Plug for 4.6 Discussion N/A & Supercharged!
Old Jul 15, 2024 | 04:42 PM
  #61
m05fastbackGT's Avatar
Originally Posted by rocknrod
Yep I didnt put it on the threads?
And of course in any torque chart there is a dry and lubed torque value.
Regardless of dry and lubed torque values, I follow the Ford TSB recommendations which does not recommend applying nickel-anti seize anywhere but on the spark plug barrels... It's worked flawless on three different spark plug changes, so if that is what Ford recommends, then so be it..
Old Jul 15, 2024 | 05:01 PM
  #62
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
Yep that's what I sure did, follow the TSB. Regardless of what anyone else told me.
Old Jul 15, 2024 | 11:04 PM
  #63
Couldn't agree more!
Old Jul 16, 2024 | 04:30 AM
  #64
05stangkc's Avatar
I Did Not Realize The Accell Plugs Were Not The Enclosed End Style Plugs! So Yes Gapping Would Be Advisable. Also Read Post as You HAD .030 Vs .032 On Enclosed Style Plugs.
DOH!
https://www.holley.com/products/disc...ct/parts/346C1
KC
Just, As an FYI For Future Viewers Here is The HTO Plug Gapping Process! As With Any Youtube Vid Take with a Grain of Salt Do Your Own Research at More Than One Source!
Old Jul 16, 2024 | 10:59 AM
  #65
Yes indeed on the Accel spark plugs not requiring a special gap tool, as they have a traditional J style open end as opposed to the closed end of OEM Motorcraft or Autolite spark plugs.
mibo
May 15, 2017 03:36 PM
MyFirstMustang
Aug 20, 2012 11:53 AM
red pony
2007-2009 Mustang GT/CS
Jul 29, 2010 08:55 AM
