Parking brake freezing
Old Dec 28, 2007 | 07:22 PM
  #101
theedge67's Avatar
So....what DOES the warranty you bought cover??
Old Dec 28, 2007 | 09:12 PM
  #102
nascar_bobby's Avatar
It is an 8 page warranty contract. I am going to call Fidelity Warranty Services, INC. (Saturday or Monday) to get the exact details why this is not covered. I believe it had something to do with ice and rust like ice build up caused it to rust. Rust void the warranty according to the contract.
Old Dec 28, 2007 | 11:02 PM
  #103
05BLKGT's Avatar
Had this problem last year and my dealer fixed it under warranty and haven't had a problem since. I would fight the dealer until they fix the problem nascar.
Old Dec 29, 2007 | 07:31 AM
  #104
theedge67's Avatar
The problem is not that ice caused a part to rust, it is that water gets into the cable sheath and freezes....freezing the cable in place. There is no rust, just ice. Once the ice melts, the problem disappears.
The underlying problem is the rubber boot that seals up the cable deteriorated and rotted away, letting water get into the cable. The rubber boot is the problem, and needs to be replaced.
Old Dec 29, 2007 | 09:53 AM
  #105
elvism's Avatar
first thing to do is check your dealerships serviceman arm for needle marks..he is cracking up.. this issue has been around since 05... they have to cover it...as for mgr or call ford.... i wouldnt worry about!! also maybe try another dealership !!!!
Old Dec 31, 2007 | 05:58 AM
  #106
Donna's Avatar
Queen Of Nascar
My car had to have it replaced and it hasn't even been cold here, and the car is garaged ALL the time. Its never even been driven in the rain but once, so I'm skeptical that its only caused by freezing conditions.
Old Dec 31, 2007 | 01:23 PM
  #107
jskibisky's Avatar
05BlkGT...
Do you recall what the dealership repaired/replaced? I've just run into the same problem on my '07 ...
Old Dec 31, 2007 | 04:03 PM
  #108
05BLKGT's Avatar
I'm not exactly positive since I don't have the repair sheet anymore, but from what I remember it was the parking brake cable. Although I could be wrong.
Old Dec 31, 2007 | 04:23 PM
  #109
MustangLynda's Avatar
Here's what's on the paperwork from when they did it on my '05:
6R3Z*2A635*F Cable Assembly - Parking Brake
6R3Z*2A635*E Cable Assembly - Parking Brake
TSB 06-5-4
Old Jan 1, 2008 | 02:24 PM
  #110
frdtch05gt's Avatar
My red '05 did this a few times when I had it, took it in and they replaced the cables. My silver '06 has been fine (knock on wood).
Old Jan 3, 2008 | 11:22 AM
  #111
Creepers's Avatar
Just experienced the parking brake problem. Do not know why it would not release. Dealer said they need to replace the cable. Luckly mine is still under the manufacturer warranty.
Old Jan 4, 2008 | 08:31 AM
  #112
beachbruce's Avatar
Brrrrrrrrr. I live in Nashville. Got cold two days ago(Jan 2) at work and my 2006 GT parking brake froze up. After driving carefully it seemed to let up.
Once arriving home I set the brake again but only pulled up half way. Upon starting car to go to work (Jan 3) it again froze up but quickly released as I live on a hill. I didn't set the parking brake again. Took it to
the dealer this morning to have issue resolved. Lets see what happens.
I put a copy of Fords TSB in with my keys in the key drop box. Hopefully they at least can read.
Old Jan 5, 2008 | 06:42 AM
  #113
jskibisky's Avatar
... good information... thank you !!
Old Jan 6, 2008 | 07:49 PM
  #114
beachbruce's Avatar
Dealer took a look but since the weather warmed up, they couldn't recreate the problem. However, I was told that they took a look-see and brakes, rotors, calipers all looked normal. The service advisor at Champion Ford said they greased it up and lubed whatever needed to be lubed, and to bring it back the night before a hard freeze again to see if the problem persists. Lets see, now if I do that, how in the world am I gonna get to work-a cab? Or maybe I could walk the 8 miles? No bus service to my work, rent a car? Lets keep our fingers crossed this doesn't happen again. BTW the TSB didn't include my car, only the Mustangs prior to the date mine was made. Stay tuned for news!!!!
Old Jan 6, 2008 | 08:39 PM
  #115
mrv8outboard's Avatar
beachbruce
check the tsb i think it said to look at the boots for detieration. i gave my dealer the tsb and told them the boots were detieriorated. they did it no questions.
Old Jan 7, 2008 | 06:40 AM
  #116
WERKED 66's Avatar
i had it done under warranty......now when it`s cold i dont use the parking brake...i use my other cars as much as possible
Old Jan 7, 2008 | 07:47 AM
  #117
Sounds weird to me - you can SEE the problem without having to experience it. Also, I had asked about my '06 and it was still summer. They said they would be able to tell by the part numbers if I had the undated cables or not, and if not, they would replace them because they already knew the old ones wouldn't last.
Old Jan 7, 2008 | 07:16 PM
  #118
dustindu4's Avatar
9 is not my lucky number.
so wait a minute, they have an updated design now or are they selling us the same crappy cable that will deteriorate and happen again?
Old Jan 7, 2008 | 08:09 PM
  #119
My '06 was produced very close to the TSB date, so they checked the cables. Anything produced after 10/1/05 should have the updated cables, theoretically.
Old Jan 8, 2008 | 01:01 PM
  #120
theedge67's Avatar
There is an updated design, the part numbers are different I believe.
