New exhaust rattle TSB released. Anyone have a copy they can post?
Old Feb 17, 2008 | 03:26 PM
classj's Avatar
Hi all,
I read on another forum that Ford has updated the rattle/noise from center stack TSB (06-4-1).
The new TSB is 08-3-4 and replaces 06-4-1.
It supposedly involves removing the old hose clamp mod (which I have not done yet), and doing the new service procedure.
Anyone have a copy they can post? I have not gotten under the car yet, but I have a lovely 1200rpm exhaust buzz that is driving me up a tree and I have a feeling this might be the ticket.
Thanks!
Old Feb 17, 2008 | 05:58 PM
StangNut's Avatar
Here ya go...
File Type: pdf
Old Feb 17, 2008 | 06:21 PM
classj's Avatar
Thanks!!
Old Feb 18, 2008 | 02:13 AM
06GT's Avatar
So it's just eliminating the mid-mounts completely, now? Interesting...I'm surprised they don't have the techs cut off the hangers as well, just in case.
Old Feb 18, 2008 | 08:26 AM
Lime GT's Avatar
Interesting is right.
They remove the isolators because they were "only needed at assembly". So now if anyone removes the exhaust and tries to reinstall it, it'll take 6 hands to get it back in place.
Why didn't they remove the isolator, bend the pipe hanger to the 2" clearance and reinstall the isolator assy? Too much time involved? Does the exhaust shift so much under conditions it will still touch the isolator's steel bracket?
I don't have the vibration problem on mine, yet but I think I'd just try bending the pipe hanger first before removing the isolator permanently.
Old Feb 18, 2008 | 12:39 PM
RRRoamer's Avatar
Can't fix it? Cut it off! That piece might technically be a "production line aid", but it SURE does make a world of difference when you are installing the H-pipe while laying on your back...
Old Feb 18, 2008 | 06:37 PM
Dineau's Avatar
I had this problem with mine when I converted to duals, I had fixed it by bending the hanger and making sure it's right in the middle of the isolator, not touching any of the side walls of this hanger.
It worked fine with mine reducing drastically, but not completely eliminating the vibration. But nothing to complain about !
Old Feb 18, 2008 | 07:02 PM
S197 V6's Avatar
Mines doing this too. Had the original TSB performed and it went away for a little while but it has come back but not as bad as it used to be. Can you get a TSB performed even after your car has gone out of warranty? Im guessing you can, but will they charge you for it then?
Old Feb 19, 2008 | 06:12 AM
Rash's Avatar
Couldn't you just put some foam tape between the hanger rod and the mount where they're touching?
Old Feb 19, 2008 | 07:50 AM
69Mach1-409's Avatar
My 08 doesn't have the hangers on the H at all... yet the mounts are still on the trans member.
Old Feb 19, 2008 | 03:44 PM
S197 V6's Avatar
Wouldnt it just melt eventually?
Old Feb 19, 2008 | 09:30 PM
classj's Avatar
idk.... I am certainly going to take a good look at those mounts and the bell housing inspection plate for possible rattles. But I am not so sure I will be hacking them off any time soon. I might just replace the mounts if they are shot.
Old Feb 24, 2008 | 02:27 PM
Ruphix's Avatar
Any solution without removal or cutting the mounts?
Old Feb 25, 2008 | 01:00 AM
Etnix's Avatar
I think my 08 has started doing this. I have about 9k miles and in the last week started hearing a rattle when in 2-3rd gear around 2k rpms....guess Ill be taking mine into the dealer.
Old Mar 12, 2008 | 02:13 PM
BuzzyStang05's Avatar
For one who has been under the car messing with the mid-pipe too many times to count I agree. Though I don't know why they don't just tell you to cut off the hanger from the H rather than cutting off the mount from the crossmember. Seems a lot easier and less labor intensive...
Old Mar 30, 2008 | 08:35 PM
Cam07's Avatar
I had dual exhaust put on and they didn't instal any brackets around the middle of the system so should I not have this TSB performed?
Ecostang
Nov 3, 2022 08:50 PM
apial
Sep 6, 2015 10:40 AM
tony2014mustang
Aug 9, 2015 03:04 PM
