Major electrical issue(s) but car still runs
Old 9/24/13 | 08:11 AM
05YellowGT's Avatar
If it's been raining, check for moisture in the carpet on the passenger side foot well, as mentioned if the SJB gets wet the computer will do strange things.
Old 9/25/13 | 07:06 PM
Lime GT's Avatar
I would check Grounds 101, 102, 103 and 107 in the engine compartment. Make sure they're tight to the chassis.
Old 6/4/14 | 08:27 PM
Barbara Richards's Avatar
Okay so I have 09 - radio came on by itself and then wipers - crazy electrical stuff. Took it to the dealer cause we know that it should have a life of its own. $1000 (min) to fix the junction box cause somehow I got water in the system according to Ford. Ford says no recall on Mustangs but this electrical stuff sounds on going
Old 6/4/14 | 08:35 PM
stupidgenius36's Avatar
Just Plain Rude!
Recalls are for safety issues. This thread is also old.
Old 6/5/14 | 07:02 AM
05YellowGT's Avatar
Ford did a poor job with the seam sealing on our cars, that's where most of us get the moisture in the SJB from. There is a TSB for the water leak in the passenger side foot well, there are several ways it can get in. I took mine in after warranty so I had to pay for it, took them three tries to fix it. This is a prevalent problem and IMO Ford should've had to do a recall, and any problems caused buy it they should've had to fix for free.
Old 6/5/14 | 07:30 AM
Getportfolio's Avatar
Four year old thread. I hope the OP fixed his car by now. Lol
Old 11/1/22 | 12:15 PM
kdphoto's Avatar
horn wire going to SJB
Lost the horn months ago nothing when I pushed it. I'm putting in a new radio so got most of the front apart and decided to look at the horn issue again. Read some of the threads so tried to look over the wires sort them out, tried the horn it worked. Started to put them back and the horn stopped working again. Obviously, the wire is loose somewhere not the SJB. will post again if I find where it's loose but right now the wires are spread out and the horn works.
Old 11/1/22 | 03:00 PM
m05fastbackGT's Avatar
Did you also read the last post submitted on this thread was from over 8 years ago
Old 11/1/22 | 03:12 PM
kdphoto's Avatar
Old
The car is 16 years old, they're all going to be old threads, Do you know of a newer one that helps? thanks
Old 11/2/22 | 03:52 PM
There are current threads directly related to the 2005-14 S197 models.. I suggest you start by searching the sub-forums by selecting the search function drop down menu.. When the search window box displays, type in electrical issues and you will then come across a listing of thread submissions... Choose the thread topics which are directly related towards electrical issues... Hopefully, you'll come across the latest thread submissions which address electrical issues such as yours
Realdeal
11/9/22 03:49 PM
Bbonis11
6/9/19 06:11 PM
Drottomon
12/18/13 12:37 PM
Chilliwack 42
15
6/19/08 01:47 AM
SuperWill
12/8/05 04:57 PM
Quick Reply: Major electrical issue(s) but car still runs
