key gets snagged in ignition switch
Old Oct 18, 2007 | 11:48 AM
clintoris's Avatar
Anybody have any trouble with their key getting hung in the ignition switch when they try to pull it out? It just started happening to me. It acts like a brand new key was just cut and hasn't had a chance to wear the burrs off.... but it's not a new key. It's a very worn-in key. I'm thinkin' the problem is in the switch assembly... but I wanted to know if anyone else had the trouble before I take it to the dealer.
Old Oct 18, 2007 | 03:05 PM
MustangRetribution's Avatar
I havent had any issues, how often is this happening? and does it snag partway out or when you first try to remove it?
Old Oct 21, 2007 | 06:53 AM
lattjolarsson's Avatar
Do you have auto or manual?
I have auto...and two times I have had some minor issues in getting the shifter in P, and if that happens the key is not possible to take out. Not sure why I couldnt get the shifter to go into P, but I backed the car up a little and forward again in the garage, and that helped.
Old Nov 1, 2007 | 02:23 PM
clintoris's Avatar
It snags all the time. I have a manual. It just seems that the switch is getting worn out.. like internal parts aren't lined up properly.
Old Nov 1, 2007 | 04:12 PM
Mustang05's Avatar
Mine just started having trouble putting the key into the ignition. I have about 25k on the clock
Old Nov 2, 2007 | 05:07 AM
Lime GT's Avatar
Are you hanging lots of weight (extra keys) off your key ring? I found at work drivers with around 10 or more keys on one key ring would wear the key lock tumblers out prematurely.
Old Nov 2, 2007 | 01:03 PM
the only thing that I keep on my ring is the remote
Old Nov 2, 2007 | 02:25 PM
HAMRS_gt's Avatar
a slight dab of lithium grease on the key may help, but I don't know all about the internals of the ignition mechanism
Old Nov 4, 2007 | 04:48 PM
06GT4RAD's Avatar
Sounds like a tumbler is hanging up. I would go ahead and try the dab of lithium grease and take the key in and out a few times and see if it helps. If not then a trip to the dealer may be needed. I know ford had a huge problem a few years back with the ignition locks on the Focus's Keys would get stuck and not come out and various other stuff.
Richard
tang65c
Oct 6, 2015 07:39 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
jim010
Sep 14, 2015 10:15 PM
