Key FOB not working
Old Oct 24, 2008 | 04:30 PM
Rampant's Avatar
Key FOB not working
Even though I usually change my own oil, I took it to a mechanic because I was low on time (yeah, I know, lesson learned). Anyway, now nothing on the key FOB will work. Not only that, the door locks won't work when putting the key in the door (I can lock/unlock only the driver side).
Interestingly, they door locks work fine when using the inside switch. And everything else seems to be OK (drove home fine, radio works, etc.)
Any ideas as to what happened or how to fix it?
(and no, my door lock fluid isn't low )
Thanks.
Old Oct 24, 2008 | 04:36 PM
05stangkc's Avatar
Check the Battery in the Transmitter??
Old Oct 24, 2008 | 04:37 PM
Rampant's Avatar
I am about to do that, but the fact that the key doesn't work in the door is what got me. Also, the fact that it happened right after the service.
Old Oct 24, 2008 | 04:40 PM
05stangkc's Avatar
Might Also Try Disconnecting the Car Battery For About 10 min and Then Check it out.
Kc
Old Oct 24, 2008 | 05:47 PM
Rampant's Avatar
Update: neither has worked yet (disconnected battery, and replaced FOB battery).
Thanks for the suggestions though.
Old Oct 24, 2008 | 06:55 PM
karman's Avatar
It always did that. You are used to using the fob.
Now you can read the manual on how to reprogram the fobs.
Old Oct 24, 2008 | 09:59 PM
05fordgt's Avatar
Hey Rampart, you may just have to re-program the remotes. Its REAL simple. Here's what you do:
1. Get in car, and shut doors.
2. Have BOTH remotes with you.
3. Put key in ingition
4. Cycle key from OFF position to ON position (but don't start the car, just ON position) 8 times within 10 seconds, with the 8th time ending with the key in the ON position
5. When you do this correctly, the locks will cycle (lock and unlock). This signifies your in "program mode"
6. Once they cycle, push the lock button on Remote #1, then lock button on Remote #2 (and do the same for any more subsequent remotes)
7. Turn key back to OFF position (locks will cycle one last time, to signify leaving "program mode"
8. DONE! Try each remote. They should work like champs!.
Hope this helps bud.
Old Oct 25, 2008 | 09:11 AM
Rampant's Avatar
Thanks a lot for the help.
Too bad I only got one key from the dealer.
I will go have them fix it.
Thanks again.
Old Oct 25, 2008 | 10:28 AM
karman's Avatar
Thanks again.
If you read the manual (or Jeff's nice instructions) you will see it only takes one key.
If all you have is 1 key and 1 remote you should still be able to re-program.
Old Oct 26, 2008 | 10:00 PM
Rampant's Avatar
It worked perfectly -- thanks everyone!
For some reason, I thought I had to have two. Can you get a new key FOB and program it the same way?
Thanks again. It was so frustrating without the FOB
Old Oct 27, 2008 | 04:56 PM
karman's Avatar
Yup.
"6. Once they cycle, push the lock button on Remote #1, then lock button on Remote #2 (and do the same for any more subsequent remotes)"
Old Oct 29, 2008 | 09:36 AM
GottaHaveIt's Avatar
hum maybe fobs were swapped ? and yup have to do all fobs @ the same time.
JT_Kwik
Nov 29, 2022 01:45 PM
tang65c
Oct 6, 2015 07:39 PM
samjluck
Sep 17, 2015 10:24 PM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
