Gas pump trigger always releasing
When I try to fuel my 05 stang the gas pump's trigger will always release when I lock it to pump fuel. This also happen if I hold the trigger with my hand and not allow me to fill my gas up. Also my check engine light is always on so I went to get it checked and was told my gas cap was bad. I replaced the cap and reset the check engine light and it still is on so I'm wondering if that also has something to do with the gas pump problem.
The fuel filling problem is as old as these 05s. It has to do with the nature of the saddle bag type fuel tank. It has happened toe once or twice also. The tried and true method is to rotate the fuel nozzle 180 degrees and in effect fill it up with the the fuel nozzle upside down. It will work like a charm.
On the check engine light have the code read. I have a handheld tuner do I can do my own, but I understand that you can go to a place like AutoZone and they can read it and give you the code. Them go online and google the code and see what the problem is.
Thanks for the info. Yeah I have been actually pumping it upside down. I just worry sometimes because of the warning message on the gas pump saying not to do that. I also noticed a smell of gas after I fill my tank up to full when I'm inside my stang.
Are you the original owner? I ask because someone may have done something to modify the car or drilled a hole to run wires or something under the back seat that would let the vapors in. But you shouldn't smell gas in the car after a fill up unless it's on you or you left the door open.
Take a look under the car or look in the trunk under the carpet or even under the rear seat if you can. Gasoline is not to be taken lightly.
Maybe someone else here knows more.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
I lust for a M24
I had this problem. Take apart the evaporator canister, the emissions crap under the black piece of steel underneath your car, behind the spare tire well. Take compressed air and blow it through all the plumbing. If new fuel is being added to the tank, the air it displaces has to vent out. If the vents are clogged, I think it can trigger the fuel shutoff since it thinks the tank is full. This worked for me. Here's some pics I drew up a few years ago describing what I thought the problem was. Not saying that this is for sure your problem, but this was my diag and my fix worked for me. I used to never be able to get it to take gas, but now I haven't had a problem in years. Someone's also said that the tanks are also joined at the bottom, but I've spent a lot of time under my car and never noticed anything.
![](http://i45.photobucket.com/albums/f93/jmbiviano/EmptyTank.jpg)
![](http://i45.photobucket.com/albums/f93/jmbiviano/FillingTank.jpg)
![](http://i45.photobucket.com/albums/f93/jmbiviano/AirBeingCompressed_0002.jpg)
![](http://i45.photobucket.com/albums/f93/jmbiviano/Vent_0003.jpg)
![](http://i45.photobucket.com/albums/f93/jmbiviano/Blocked_0004.jpg)
![](http://i45.photobucket.com/albums/f93/jmbiviano/Fixed_0005.jpg)
I use the lowest possible speed when filling, and that allows the air to not be a problem.
I only have this issue when I pump the gas in full tilt boogie... and if I'm near empty, amazingly, at 7gallons, almost exactly... which would be the left half bein' full.![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
But slowly pumping the gas in will alleviate the issue. If there is no 'slow' pump speed, then I have to turn it upside down too.
I'm gonna bet the reason you smelled gas is because upside down, the pumps with a tube on the spout can't get a good seal, so the vapors fly out the inlet. Using the pumps with the vapor recovery on the inside of the car's inlet instead of the outside with the tube, you won't have that smell.
/Go out in the country where they aren't yet mandated to use those recovery things, such as Huntsville, Texas (last I was there, anyway), and boy, those stations *reek* of gas. Ugh.
What u are saying about the pump being upside down sounds pretty good. I agree but thats the only way i know of to fill my tank up is to hold the pump upside down.
I lust for a M24
It's all removed from the tank. Kind of like how changing a headlight isn't going to put you in danger of being shocked by the battery. Like I said, don't know if this is your problem, but blowing everything out did fix my problem.
