View Poll Results: Have you ever had the fuel pump nozzle shut off before tank was full?
Yes. It happens just about every time I try to fill up
![](https://themustangsource.com/forums/images/polls/bar2-l.gif)
![](https://themustangsource.com/forums/images/polls/bar2.gif)
![](https://themustangsource.com/forums/images/polls/bar2-r.gif)
![](https://themustangsource.com/forums/clear.gif)
24.32%
Yes. I've had it happen every now and then.
![](https://themustangsource.com/forums/images/polls/bar3-l.gif)
![](https://themustangsource.com/forums/images/polls/bar3.gif)
![](https://themustangsource.com/forums/images/polls/bar3-r.gif)
16
43.24%
Yes. But I have to invert nozzle to fill tank
![](https://themustangsource.com/forums/images/polls/bar4-l.gif)
![](https://themustangsource.com/forums/images/polls/bar4.gif)
![](https://themustangsource.com/forums/images/polls/bar4-r.gif)
10.81%
No. I can always fill my tank completely without inverting nozzle or having it shut off prematurely
![](https://themustangsource.com/forums/images/polls/bar5-l.gif)
![](https://themustangsource.com/forums/images/polls/bar5.gif)
![](https://themustangsource.com/forums/images/polls/bar5-r.gif)
21.62%
Voters: 37. You may not vote on this poll
Fuel Fill Problem Poll
Doing some data gathering on the S197 Fuel Fill (premature nozzle shutoff) problem. Ford has replaced my entire EVAP emissions system, and nozzle still shuts off at 1/2 tank (only fills driver's side saddle tank). Every now and then, if I flip nozzle between 2 and 3 o-clock position, it will fill all the way up.. but that is not the answer. Anyway, Ford has agreed to send out an Engineer to evaluate my car. I'd like to take back some data showing Ford this is not an isolated problem. Your input is greatly appreciated.
1 Post
I lust for a M24
You're FAR from alone. Here's a thread I posted on the issue a while back. Since I made the fix myself, I haven't had any problems, although who knows if they'll return.
http://forums.bradbarnett.net/showthread.php?t=462079
There are class action lawsuits about this:
http://www.mustangfueltankproblemsslowtofill.com/
http://www.lemonlawcenter.com/mustang-fuel-tank.htm
including problems overseas:
http://www.stripes.com/article.asp?s...9&archive=true
Also:
http://forums.bradbarnett.net/showth...ight=fuel+tank
And those are just threads within the last year after a quick search. They go on, and on, and on.
Also:
You know I have heard of this problem before, however, I seem to have the opposite problem. I have an 06 and there is a local station that installed new pumps, if I fill up there at the highest speed I end up having overflow. I've had this happen at other stations as well. Gas will flow out from underneath the car and some will spill out from the nozzle and run down the side of my car.
I have had slow fills and persistant stops, but have been easily able to cure that with inverting, turning the nozzle upside down.
Only once have I had to leave the station because of rediculously slow fill and that was not because of the car, it was the station.
I have zero problems filling the tank with the nozzle upside down. It seems to be dependant on the station, if one pump doesn't work normally chances are all won't. Same goes if the pumps Do work.
It's not really that much of an inconvieniance, atleast to me. Or rather it hasn't been bad enough to prompt me to go try and get it fixed. The skipper 500 is more a pain in the butt IMO, although I haven't gotten that looked at either.
Rando
8/25/21 11:12 AM
