Fuel Fill problem...(not the normal one)
when i fill my tank...the guage doesnt move from where it was...it takes a while to go up
also the digital readout does the same thing with "Miles to E"
however it goes down just fine
<div class='quotetop'>QUOTE(CHDS PNY @ April 22, 2006, 8:57 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
turning key off/on make any difference?
[/b][/quote]
<div class='quotetop'>QUOTE(ford4v429 @ April 24, 2006, 5:35 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
nope...it eventually *slowly* goes back up
[/b][/quote]
May 2007... My 2005 GT just started doing same thing. Drops to empty after four miles of driving, Stays there. I tried hitting bumps, sway car, going up & down hills, filling tank, nothing but stopping and shutting motor off has helped.. Now check engine light is on. Gauge will come up to normal after it sits a while but needle flucuates a 1/8 of a tank up and down. Always had Chevron so Tectron isn't answer. Some web sites say both computer wires have to be relaced left and right side to tank???????
I've noticed the same thing if the ignition was still on even if the car was not running.
The best thing to do is just turn the key completely to "Off" and then when you restart the car, it should go back up to "Full" right away - mine does.
unnoticedtrails
Jul 17, 2017 11:10 AM
