Fuel Fill problem...(not the normal one)
Old Apr 22, 2006 | 08:54 AM
CHDS PNY's Avatar
when i fill my tank...the guage doesnt move from where it was...it takes a while to go up
also the digital readout does the same thing with "Miles to E"
however it goes down just fine
Old Apr 24, 2006 | 04:32 PM
ford4v429's Avatar
legacy Tms Member
<div class='quotetop'>QUOTE(CHDS PNY @ April 22, 2006, 8:57 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
turning key off/on make any difference?
Old Apr 25, 2006 | 06:51 AM
CHDS PNY's Avatar
<div class='quotetop'>QUOTE(ford4v429 @ April 24, 2006, 5:35 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
nope...it eventually *slowly* goes back up
Old May 12, 2007 | 04:42 AM
SchatzieII's Avatar
May 2007... My 2005 GT just started doing same thing. Drops to empty after four miles of driving, Stays there. I tried hitting bumps, sway car, going up & down hills, filling tank, nothing but stopping and shutting motor off has helped.. Now check engine light is on. Gauge will come up to normal after it sits a while but needle flucuates a 1/8 of a tank up and down. Always had Chevron so Tectron isn't answer. Some web sites say both computer wires have to be relaced left and right side to tank???????
Old May 12, 2007 | 06:56 AM
Speeddmn's Avatar
is the car running when you fill up? I have had the same problem with both sdtangs and my truck if it was running when I filled up.
Old May 12, 2007 | 07:51 AM
Steve's Avatar
I've noticed the same thing if the ignition was still on even if the car was not running.
The best thing to do is just turn the key completely to "Off" and then when you restart the car, it should go back up to "Full" right away - mine does.
Old May 12, 2007 | 10:40 AM
CHDS PNY's Avatar
mine was fixed back in november
a "Sulphur Buildup" on the Fuel Sending unit
it was warrantied
Old May 12, 2007 | 10:45 AM
kevinb120's Avatar
Yea why bother, just take it in to get fixed
When fueling, never fill modern vehicles with the key in the on position, running or not. All manuals from all makers will say not to do it.
kponypower
Jun 17, 2020 07:17 AM
unnoticedtrails
Jul 17, 2017 11:10 AM
GLOCKer
Sep 28, 2015 05:20 PM
southern stang
Sep 26, 2015 04:19 PM
