Driver's Side Mirror Loose
Old May 12, 2007 | 07:14 PM
tucsondivots's Avatar
Question Driver's Side Mirror Loose
The driver's side power mirror is loose and needs to be tightened.
I brought this up during my dealer visit for an oil change today and they said it would take a few hours to tighten because the entire door panel must be removed. Is this accurate? Has anyone had to tighten a loose mirror on their 2005?
Thanks.
Old May 12, 2007 | 08:24 PM
07 HOSS Mustang's Avatar
They are full of it,Tuscon. If you pop off the mirror cover inside the door there are 3 nuts that you can see to tighten. They shouldnt be loose though. Its a 10 minute jod to do BOTH sides...
07Hoss
Old May 12, 2007 | 09:20 PM
07 Hoss: Thanks. I wondered about that. Does the **** for adjusting the mirror just pull off then that cover justs pulls off?
Old May 13, 2007 | 02:25 AM
ShowGT's Avatar
The triangle cover is not part of the door panel, just gently pry away from the door itself and make your needed adjustments.
Old Dec 28, 2008 | 10:39 AM
Woodward Ave's Avatar
My mirror housing is on fine, but the mirror itself is loose - ie I can move it with my finger and light pressure. Will these bolts tighten that up?
Old Dec 28, 2008 | 04:56 PM
SD CALSPCL's Avatar
I had, basically, the same issue. I was washing the car and felt the housing move. I removed the inner cover and checked the bolts. They were tight, but the housing was still loose. I showed this to the tech when I took her in the an oil/filter change. They checked it and found two support pieces (?) inside the mirror itself were broken. This caused the whole housing to move and appear loose. Since there was no indication of damage on my part (i.e. the outside of the mirror was pristine),the mirror was replaced under warranty.
Old Dec 29, 2008 | 09:58 AM
jodadejSS06GT's Avatar
Same with mine! Loose, took it in, they took the mirror off and pieces were broken so they replaced under warranty.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
NC14GT
Sep 10, 2017 04:47 PM
Fedupdave42169
Oct 23, 2015 09:58 AM
Airborne42
Sep 25, 2015 05:14 PM
DrisStang
Sep 14, 2015 06:20 PM
