Disconnect Neg. Battery Terminal?
Old Oct 14, 2005 | 11:26 AM
NickDC123's Avatar
Many installs tell you to disconnect the negative battery terminal first. Why? Does this reset all the computer stuff?
Old Oct 14, 2005 | 11:29 AM
MaverickMLFD371's Avatar
yes, some of the stuff you put in, the computer needs to relearn the new modification to gain the max performance. it also is a safety issue, you never want to work on a car with the batter plugged in.
Old Oct 14, 2005 | 01:58 PM
I8URVTEC's Avatar
It does reset the computer to a degree but you don't loose your custom tunes if you have any. That is flash memory so it is flashed right into the computer and does not go away unless it is deleted or overwritten.
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
BigHoss
Sep 21, 2015 10:03 AM
