Cold start, low rpm
Old Apr 30, 2010 | 02:01 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Cold start, low rpm
This has happened a few times since i've gotten the car, but only when its cold out, and generally only when I leave it outside of the garage(therefore making it colder). It also ONLY happens on first start up in the morning. I'll put the key in the On position, let it ding, then i'll start it up. Basically, as easy as I can explain, the car stutters and hits about 250-400rpm's for a few seconds, then revs up to the normal 1,500rpm's, down to 1,000, then down to the normal "warm" idle of 750 after a few minutes. Also while at the low rpm's, there is no response to throttle.
Also, if I don't let the car sit and warm up until it hits the normal idle rpm's, it feels laggy on initial drive. It'll bog down a bit and feel like it has some loss of power. Keep in mind, getting to that normal idle takes several minutes, depending on how cold it is so being that its still very close to factory specs, it shouldn't need a 5-10 minute warm up to drive properly.
Anyone?
Beuller...
Beuller.......
Old Apr 30, 2010 | 02:10 PM
Nope not Ferris.
But.... clean the throttle body and MAF?
Found this. Should apply to S197? (at least conceptually)
http://www.muscularmustangs.com/maf.php
Old May 1, 2010 | 08:55 AM
Founding MOTM
Committee Member
Originally Posted by cdynaco
Nope not Ferris.
You know, I thought it was the tb as well. I'll have to try it out when I get some time one of these days. I guess the car knew I was looking for answers since it stopped doing it again.
Old May 1, 2010 | 10:29 AM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
are you saying that ur stang is onto you?
Founding MOTM
Committee Member
Precisely.
Old May 3, 2010 | 05:32 AM
05YellowGT's Avatar
Funny how it sure seems that way sometimes ...
Old May 10, 2010 | 05:50 PM
Cavero's Avatar
mine seemed to do that too. was doing it real bad when it was cold and damp out, hasn't shown up for months
Mpaps
Oct 11, 2017 08:06 PM
Evil_Capri
Aug 27, 2015 01:08 PM
ClayP
Aug 3, 2015 09:00 PM
Ecoboost
Jul 25, 2015 06:32 PM
Ecostang
Jul 11, 2015 09:06 AM
