Clunking sound
Old Dec 5, 2007 | 04:03 AM
Chilliwack 42's Avatar
Clunking sound
I've noticed my car was making a bit of a clunking noise from what sounded like something in the rear end. I have steeda LCA Relocate Brackets and Billet LCA's, but this clunking has been around prior to that. It usually happens when upshifting or downshifting in lower gears. I find it gets worse after a long trip. If I'm in a lower gear and tap the gas pedal it's very noticeable. After listening to it today I have a feeling it is coming from my driveshaft. If I grab hold of it and twist it there is some play in it(not at the bolts). Is this normal? I want to take it in to my dealer to get it checked out I'm just worried they're are gonna be a pain about the LCA Brackets.
Old Dec 5, 2007 | 05:58 AM
why did you put the relocate brackets on? They are usally used on lowered cars. I wonder if they may have slightly messed up your pinion angle
Old Dec 5, 2007 | 04:10 PM
I put them on for better traction at the track.
Old Dec 5, 2007 | 05:45 PM
It was all done on an aligment rack. The rear end shouldn't have really moved too much. Even if the pinion angle was out a bit I couldn't see it causing a clunk if I tap the gas pedal. It's more like something is loose, I just don't know what.
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
oldnjguy
Sep 10, 2015 02:39 PM
