Check Engine Light Warning
Old Jun 5, 2011 | 09:39 PM
jim010's Avatar
I've had my Mustang now for 6 years and 120 000 km. It is a GT convertible. Driving home from the mountains today the Check Engine warning lit up.
I need to take it in for the 120 000 km service anyway, and I do have the Ford extended warranty upto 150 000 km for 500 components.
What questions should I be asking before they start diagnosing the problem?
What is wired up to that light? What are some possible problems associated with it?
I just want to be informed before I take it in, as it may not be covered.
Cheers
Old Jun 5, 2011 | 10:02 PM
Everett's Avatar
Cats might be done in. Has is gotten any harder on fuel. Any drivability problems. Could be as simple as an o2 sensor
Old Jun 5, 2011 | 10:08 PM
jim010's Avatar
Mileage did seem a bit worse than usual on this trip.
Old Jun 5, 2011 | 10:17 PM
jim010's Avatar
Is that indicative of the catalytic converters, or the O2 sensor?
I not well informed when it comes to these things.
Old Jun 5, 2011 | 10:21 PM
Everett's Avatar
Well if it is a sudden change that means something with the motor changed. And the o2 sensors are crucial in the motor managing itself properly. When mine went bad I had less power and it got really bad on fuel.
Old Jun 5, 2011 | 10:27 PM
jim010's Avatar
Hmm. It got worse mileage on the trip, but not by a massive margin. Light didn't gone on until I was almost home. (I did hit a pretty big dip in the road, though). Still, is replacing the sensor a big deal?
Thanks for the help, by the way.
Cheers
Old Jun 5, 2011 | 10:58 PM
jim010's Avatar
Is it just those 2 possibilities, by the way?
Old Jun 6, 2011 | 12:36 PM
conv_stang's Avatar
If you have an Autozone or an Advance Auto Parts near you, you can take it there. I know here in the states they will hook up the scanner and pull the codes for you for free. That is a good place to start
Old Jun 6, 2011 | 12:41 PM
jim010's Avatar
I would need the Alberta equivalent. I'm not sure where to go for a free diagnostic. Otherwise, I need to pay $100 for the dealer to do it.
Old Jun 6, 2011 | 01:23 PM
Everett's Avatar
It could be alot of things. I don't know if part source clears codes.
Old Jun 19, 2011 | 08:30 AM
DaTT(1sK)'s Avatar
Parts source won't do it in Canada...at least in Ontario.
Best bet is to have a mechanic friend do it....or buy an OBDII reader for no less than $150
Ecostang
Nov 3, 2022 08:50 PM
ClayP
Aug 11, 2015 06:23 AM
Bert
Jul 25, 2015 02:13 PM
Will3212
Jul 16, 2015 10:30 AM
