Air Bag Light TSB
Old Oct 6, 2005 | 08:02 PM
True_HP's Avatar
Two weeks after getting my car the air bag light came on. I did some research and found the TSB. I pulled all the info and there is two options... One is trying to find a ground fault somewhere in the wireing... two is to have the computer swapped out. That means taking apart the whole dash and I'm worried the dealership is going to mess up the reinstallation and turn my baby into a rattle trap.
Has anyone experienced the same issue and what was your outcome
Old Nov 15, 2005 | 12:09 PM
Trampus's Avatar
What did you end up doing?
I've noticed that when my wife is sitting in the passenger seat, the air bag light will turn on and off at random times.
Old Nov 16, 2005 | 02:51 PM
WERKED 66's Avatar
there is a senors that reads if someone is sitting in the seat or not also if they dont weigh that much as in case you have a child there it will deactivate it...i beleave it is 75lbs or something like that.....
Old Nov 17, 2005 | 12:22 AM
Indystang's Avatar
Yes something like this is true. Last week I placed a rather heavy sack of groceries in the seat and mine came on too. It displayed the "Passenger Airbag Off" message. I believe 75 lbs. should be enough weight though. Better get it checked out.
Old Nov 19, 2005 | 12:02 PM
"05 Saleen's Avatar
I had the same problem with my passenger airbag. I took it in and they replaced the airbag switch in the seat, they also replaced the airbag and cover (to fix the rattle) at the same time. Since then the light only comes on when I have someone between 25 and 75 pounds in the seat.
Old Dec 15, 2005 | 03:38 PM
AFChief's Avatar
My passenger light is on all the time when it is vacant too. Just started. Is that TSB for the instrument cluster light?
Old Sep 18, 2007 | 12:42 PM
krnpimpsta's Avatar
*digging up old threads*
Mine turned on and off (a few minutes at a time) with my ~100lbs gf in the seat. Anyone else experience this or know which TSB resolves this?
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
samjluck
Sep 17, 2015 10:24 PM
TripleBlack14
Off-Topic Chatter
Sep 12, 2015 01:03 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
14Glassback
Sep 11, 2015 04:50 PM
