2007 mustang gt electrical problem?
Old Nov 25, 2019 | 04:41 PM
Lexx23's Avatar
I have a 2007 mustang gt, the gear shifter will not move out of park unless I use the override switch, the driver side taillight will not turn on (turn signal won’t work either, just no power going to it at all), and the passenger side headlight won’t work either, I checked the fuses they all work, changed the bulbs out and still won’t work, also replaced the brake light switch nothing worked, pulled apart the wiring harness that connects to the fuse box couldn’t find anything burnt or out of place Also all three things happened at the same time.
Old Feb 21, 2021 | 09:04 PM
Chad07gt's Avatar
Help
[QUOTE=Lexx23;7046215]I have a 2007 mustang gt, the gear shifter will not move out of park unless I use the override switch, the driver side taillight will not turn on (turn signal won’t work either, just no power going to it at all), and the passenger side headlight won’t work either, I checked the fuses they all work, changed the bulbs out and still won’t work, also replaced the brake light switch nothing worked, pulled apart the wiring harness that connects to the fuse box couldn’t find anything burnt or out of place Also all three things happened at the same time.[
Hi I have the same problem did u figure it out?
Old Feb 22, 2021 | 06:20 AM
Bert's Avatar
there are two fuse boxes, make sure you check both of them, locations are in the manual
other than that, it's probably out of my league
Old Feb 22, 2021 | 06:45 AM
SpectreH's Avatar
Water intrusion/corrosion in the SJB would be my guess if it wasn't a fuse.
Old Feb 22, 2021 | 08:04 AM
houtex's Avatar
Old Feb 22, 2021 | 11:37 AM
Chad07gt's Avatar
Fuse panel
I guess I need to take it off and clean the connections any suggestions on what to clean them with? By the way thanks for replies
Old Feb 22, 2021 | 11:50 AM
Bert's Avatar
try some searches for "SJB" or "SJB water" or "system junction box water" and you can probably find the other threads with the details of this issue
Jordeck2390
Jul 9, 2022 11:01 AM
Enrique Lopez Lopez
Jul 15, 2019 06:20 PM
claysstang
Apr 18, 2014 04:03 PM
Brian Berthold
Oct 4, 2013 05:24 PM
5.0fish
Jun 29, 2011 09:18 PM
