2005-2009 Mustang Automatic gear shifter spring? Discussion
Old May 7, 2023 | 10:42 AM
Sunlvriii's Avatar
hello. In changing out my gear shift dust cover a friend of mine, who must not have understood the agenda, started messing around with the gear shift assembly - I guess it might be called- and twisted and turned until this spring came out and now I see the two little tabs- in the third pic. and I can't get it on camera, but when I look down the hole where it goes I can see where the two tabs line up and then I would imagine you twist it and it catches at some point but that's not happening. I've inserted it all the way, part of the way, twisted and I can't get it to catch so I hope it didn't get broken. Just looking for any insight as to if this needs to be in a certain gear to connect or what I need to do to get this back intact so I can finish the project. Any advice would be greatly appreciated!
Meanwhile I have to drive to work tomorrow and I'm going to go on a test drive now 🙏 because it seems to shift into every gear okay, even with the gear shift handle not on. it doesn't seem to completely go into Park so obviously I can't get the key out but I guess I will just use the emergency brake and take my fob off of the key ring and if I can't lock the car, then I can't lock it, but I mean, I got to go to work tomorrow.
Last edited by Sunlvriii; May 7, 2023 at 10:55 AM. Reason: First post- Couldn't figure out how to get my narrative in after the pics
Old May 7, 2023 | 11:18 AM
05stangkc's Avatar
@Sunlvriii
Unless You Can Repair What You Have, There are No Service Parts For That. It Will Require a Complete New Shifter Assembly. I Can Only Assume To Reinsert it the Top Of Rod Is Your Guide. Perhaps Somebody Had This Similar Issue and Can Chime in.
Base Model Black Housing
https://www.fordpartsgiant.com/parts...tra2=&filter=()
IUP Shifter ,Can Upgrade if you Have Base Black if You Like!
I Just Remembered There is an Override Slot On Side of Shifter. Look For Oval Pop out Plug on Top. Normally You Would Pop Out and Stick Your Key Etc. in It to get Out Of Gear. Should Allow you to Put in Park! Least You Can Drive Now and Remove Key! Gotta Be That Rectangular White Piece! Try Pressing and Put in Park!
Might See If Rod Can Be Reinserted While Pushing Down Interlock Overide! I think I Got an Old Shifter Somewhere. Just Not Sure Where it Would Be Got 3 Seatrains Full o Stuff. I Could advise Better if I Had One Handy. I Will Poke around a bit and Let You Know if I Find It!
A Little Grease on the Bottom of The Rod Might Be a Good Idea as Well When Attempting to Reinsert. Perhaps Using **** to Guide Rod In and a Light Tap With Your Fist. Be Advised You Could Break it No Matter What You try!
See Page 165-166 on Owners Manual!
Sorry For Your Troubles!
KC
File Type: pdf
Old May 10, 2023 | 11:41 AM
Sunlvriii's Avatar
Thank you!
Oh my gosh! The override oval - I will try that, thank you so much!
I will try getting the rod to re-catch also in different gears.
I'm planning to stop at a dealership today hopefully to see if the Parts Dept will graciously show me the schematic in case that will show me something. I'll post info here if I get anything good 🙂. Again thanks so much!!
Old May 10, 2023 | 11:59 AM
05stangkc's Avatar
You Are Welcome!
Likely This is about as Good as the Shifter Pic Will get at The Dealership!
This is Typical Parts Pics For the Shifter! BELOW
Sorry Could Not Find My Old Shifter!
https://www.tascaparts.com/oem-parts...able-8r3z7210c
Other Pics. Also See Links in First Post For Pics.
Old May 10, 2023 | 02:22 PM
05stangkc's Avatar
I'm Wondering if That Rod Goes into a Spring Much Like an Ink Pen. Possibly Simulating Threads to an Extent???
KC
Old May 22, 2023 | 08:10 AM
pinchejxuan's Avatar
Spring
Did you end up fixing it? I have the same problem atm and thinking about buying a new shifter, thank you
Old Jun 13, 2023 | 04:28 AM
RalphJones's Avatar
@Sunlvriii
KC
Spoiler
Thank you sir for the links.
BYE BYE SPAMMER!
Old Jul 18, 2023 | 09:39 AM
05stangkc's Avatar
Spammer Post 7
I Give Them New Avatars!
Bye Bye!
KC
Old Jan 15, 2024 | 07:20 PM
Pioerdrums's Avatar
Same issue.
[QUOTE=Sunlvriii;7074728]
anyone have suggestions on this I need help as well
Old Jan 15, 2024 | 08:59 PM
05stangkc's Avatar
I Think You are Going To End Up Replacing Shifter.
Here are the Best Buys on Ebay For The Upgrade Shifter!
I Would Go New as These Were Problematic From The Git Go and Ford Changed Part Numbers Numerous Times.
This Is The Latest Part Number and No Real Savings on Getting The Plain Black Shifter!
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
But If Somebody Has Repaired One Please Chime In!
KC
KC
Old May 17, 2024 | 10:04 PM
tsilvey1's Avatar
KC
KC
this is how I fixed this issue see picture description below. I had to completely remove the center console and and shifter boot. (Not that bad). You’re going to need a good light and a hooked pick is pretty much necessary. You will notice a groove/ slot in the plastic of the shifter the silver bar is probably at this point sitting below that out of the groove(at least that’s where mine stayed) you have to align and get it back into that groove
Sorry for the bad drawing but this somewhat illustrates how to fix this issue. Start my moving the shifter to neutral, then using a hook pick or something similar pull the silver lock bar up into the groove while depressing and turning the shift button until it aligns and falls into the groove once it falls into the groove you need to rotate it to lock it into place while holding the bar with pick up in the groove
Old May 17, 2024 | 10:09 PM
tsilvey1's Avatar
Solved this issue check last update
[QUOTE=Pioerdrums;7083005]
solved this check above quote
Old May 17, 2024 | 10:28 PM
05stangkc's Avatar
Solution!
Thanks For Coming Back In!
KC
Old Aug 24, 2024 | 08:15 PM
Jrich's Avatar
Thumbs up THANK YOU tsilvey1
JUST had this same problem with my 07. Didn't know what caused it and could NOT find a fix anywhere until I happened across your photo on the web. It was tricky, but it WORKED! Can't thank you enough!
Old Aug 24, 2024 | 08:25 PM
05stangkc's Avatar
That's Why We Encourage Folks To Come Back After The Brainstorming & They Get it Figured Out! It Can Be Invaluable to The Next Guy!
Also At Times I Try & Adjust Thread Title So it is Search Friendly After We Get Some Action on Thread!
Glad it Worked Out For You!
Welcome To TMS We Have Lots of Good S-197 Info Here! If You Like Go To Introductions & Post Some Pics of Your Car!
https://themustangsource.com/forums/f650/
KC
S197ForLife
Jun 3, 2021 07:56 PM
VandykeT/A
Sep 10, 2012 05:35 PM
Topnotch
Nov 21, 2008 01:12 PM
ed3sanders
Jun 5, 2008 07:44 PM
MTAS
Ford OEM Parts {Oem Ford Parts Information & Links}
22
Jul 20, 2006 05:40 PM
