'07 Auto Window Issue
Old Jan 4, 2009 | 09:58 AM
pilatti1's Avatar
Cool '07 Auto Window Issue
Last night i was driving and the window went down all by itself just as it would when you went to open the door to allow air flow. Now the window stays down that small amount to let the air flow unless I put the window up with the switch, so when I get out of the car & the window drops it stays down. Any ideas?
Old Jan 4, 2009 | 10:17 AM
CalStang'07's Avatar
Cool "Reprogram Windows?"
Sounds like you just need to reprogram your window's operation, as per your 2007 Mustang owners manual? With ignition key switched on to first position (music plays) and the engine off, run window all the way down and then all the way back up. Hold it in the up position for about two seconds with the door rocker switch. This reprogram will usually fix that problem? That is, if nothing is broken from window ice jams? CalStang.
Old Jan 4, 2009 | 06:54 PM
pilatti1's Avatar
Thanks CalStang that seemed to work. Appreciate it very much
Road_Runner
Sep 2, 2024 04:46 PM
iliveonnitro
Oct 7, 2021 06:31 PM
09-gt/cs
Oct 15, 2015 10:03 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
