VIBRATIONS
Old Jun 1, 2010 | 08:13 AM
Rogue's Avatar
VIBRATIONS
what could come and go as a vibration,
i mean from no vibration to a violent one then none again on the 67 ?
Old Jun 1, 2010 | 03:19 PM
HOSS429's Avatar
legacy Tms Member
be a bit more specific .. motor or drive train or wheels
Old Jun 1, 2010 | 03:33 PM
Rogue's Avatar
Ok i was doing like 110 and then all of a suddenit started violently shaking, i took it out of gear and it did not change, reved the motor no change
when the car got back to about 70 the vibration stopped , then i sped up and had no vibration,
best i could explain is it felt like something was coming apart,
there was also a loud humming noise
i thought i lost a harmonic balancer, but it was still there,
i guess i could have a seperated tire, but dont know
i am just wondering what components could be sparatic,
when i dropped it out of gear rpm's dropped to 700 and was still vibrating, so that was probobally not it,
with the trans could it be something inside a t5 not balanaced right or coming loose?
i am clueless in rear ends , 8" with a mini spool, could something be wrong in there?
could it be something with too much play in the drive shaft, or the angle of the drive shaft ect?
i am just looking for places to look into
it was funny though because i did beat the hell out of the car i was racing, even slowing down to 70 he didnt catch me!
Old Jun 1, 2010 | 03:37 PM
Puter's Avatar
Yeah, a lot of things that you mentioned. Once mass is moving that quickly, kinetic energy will multiply. 110MPH will find issues that are not normally there.
Tell me, did you ever fix your vibration you posted about before?
Old Jun 1, 2010 | 04:05 PM
Rogue's Avatar
yes. that was the trans hitting the trans tunnel. it was binding, i had to cut a small section out of the trans tunnel to clear the shifter thingy
Old Jun 1, 2010 | 04:07 PM
Mberglo's Avatar
Was the steering wheel shaking? Front ends on those cars aren't the best design, and are dangerous when worn out.
I've been 110 in a vintage Mustang. It's scary. Car wants to lift.
Old Jun 1, 2010 | 08:32 PM
Rogue's Avatar
definatly not the front end, it was a whole car feeling, think turbulence on a plane.
Old Jun 1, 2010 | 08:45 PM
Lennyb44's Avatar
Number Cruncher
Had a problem like this on my old Ranger.
Threw a wheel weight at 65mph.
Thought it was going to shake apart before I got the speed down.
Old Jun 2, 2010 | 07:04 AM
Mberglo's Avatar
I guess you don't have to wonder about this anymore. Just tell the new owner to keep it under 108.
Airborne42
Sep 24, 2015 11:01 AM
oldnjguy
Sep 10, 2015 02:39 PM
GMAYS
Sep 10, 2015 06:19 AM
bob
Aug 15, 2015 08:58 AM
Mug-stang
Jul 31, 2015 10:25 PM
