electric choke?
Old Dec 12, 2007 | 01:11 PM
usmcrebel's Avatar
electric choke?
ok, i've got a edelbrock thats running great, but imconfused on the electric choke, what do i hook it too?
Old Dec 12, 2007 | 01:16 PM
mgreene's Avatar
http://classicbroncos.com/forums/arc...p?t-48107.html
Old Dec 12, 2007 | 01:35 PM
usmcrebel's Avatar
thanks, i couldnt get any help on the other forums.
Old Dec 12, 2007 | 01:44 PM
Faber's Avatar
the mustang source just rules.
Old Dec 12, 2007 | 01:46 PM
usmcrebel's Avatar
+1 to that.
Old Dec 12, 2007 | 02:14 PM
usmcrebel's Avatar
is there anything special needed to adjust valve lashings?...i think that might be where im getting the "tick" in my motor from.
Old Dec 12, 2007 | 02:19 PM
Mberglo's Avatar
That depends on the heads you have. Any idea where they came from? Only the early heads need precise adjustments. I think 68 and up are positive stop.
Old Dec 12, 2007 | 02:24 PM
usmcrebel's Avatar
i think its an 1986 5.0. i havent checked the numebrs....whats a quick way to tell when i get home i can go check and post it up.
Old Dec 12, 2007 | 02:52 PM
usmcrebel's Avatar
what is positive stop, you just tighten them up and thats it?
Old Dec 12, 2007 | 05:24 PM
Puter's Avatar
Again, depends on what you have.
For what you think that you have, it should be zero lash, then torque to 18-22 ft/lbs. You also need to count the turns while doing this. You should get to the torque value between 1/4 and 1 turn. If not, you need to shim the rocker.
You adjust on the base of the cam. To determine, turn the engine in the correct rotation until the exhaust is just starting to open. You now back off the rocker on the intake, allow it a moment or two for the spring in the lifter to move it back to the neutral position, then tighten. Rotate the engine again watching the same intake rocker. It will open the valve, then close. When it is almost closed, the intake of the same cylinder is ready to be adjusted. Back off the nut, allow time for the lifter to go to neutral, then adjust.
Repeat until complete.
Some folks do not understand zero lash. I rattle or jiggle the pushrod up and down. When you get to the point that there is no play between the lifter and rocker (rocker tip is against the valve tip), that is zero lash. Also, you should adjust when the engine is warm, if possible.
Old Dec 12, 2007 | 10:11 PM
usmcrebel's Avatar
hrmmmmm, sounds like something to do this weekend, if i get sme spare time. i will ask this again to anyone onf saturday, due to the fact i am a tactile learner. thans again and in advance.
Ecostang
Nov 3, 2022 08:50 PM
redrock35
05-09 Exterior Modifications
Jul 31, 2016 08:50 PM
2012Kona
Aug 21, 2015 08:36 AM
cloud9
GT350
Aug 18, 2015 01:34 PM
YepItsGreen
23
Jul 15, 2015 07:38 AM
