Assembly Line Tags, ID's, Buildsheets
Old Nov 18, 2009 | 08:00 PM
kennyg's Avatar
If you have ever found a QC tag or card, buildsheet or special markings on your Mustang post them here.
I was restoring the dash in a '67 earlier this year and found this tag behind the heater control attached to the underdash wiring harness. It reads 'In Plant OK'. kennyg
Old Nov 18, 2009 | 08:08 PM
BA Mustang's Avatar
Here is what is left of my build sheet I found behind my cluster taped to the wiring. Some of the pieces fit together, but it was falling apart on me so I covered it before I lined them up.
Attached Thumbnails Assembly Line Tags, ID's, Buildsheets-104_6851.jpg   Assembly Line Tags, ID's, Buildsheets-104_6852.jpg   Assembly Line Tags, ID's, Buildsheets-104_6853.jpg   Assembly Line Tags, ID's, Buildsheets-104_6854.jpg
Old Nov 19, 2009 | 06:40 AM
mgreene's Avatar
From my 1970 Boss 302 - Paint OK on bottom of hood, serial number stamping on top of block and on top of toploader trans, toploader ID tag and marking - all numbers match - i.e., serial number on engine and trans match VIN on car:
Attached Thumbnails Assembly Line Tags, ID's, Buildsheets-dscn0076.jpg   Assembly Line Tags, ID's, Buildsheets-dscn0069.jpg   Assembly Line Tags, ID's, Buildsheets-dscn0063.jpg   Assembly Line Tags, ID's, Buildsheets-dscn0068.jpg   Assembly Line Tags, ID's, Buildsheets-dscn0071.jpg
Old Nov 19, 2009 | 07:21 AM
garagewear's Avatar
I remember when chemical stripping the radiator support on my 65 there were crayon markings on the battery side with the color code and interior code. I guess this was to notate as it was going down the line so they didn't have to read the small print on the sheets.
Old Nov 19, 2009 | 02:15 PM
BA Mustang's Avatar
This reminds me that my 200 still had the tag on it by the coil.
Old Nov 19, 2009 | 06:00 PM
jwebster's Avatar
Anyone have a guess as to what these markings mean? They are under the hood of my '67.
Old Nov 19, 2009 | 08:48 PM
kennyg's Avatar
In my archives (stuff filling file drawers) I have a QC card that was found under the carpet of a '69 coupe. On the card was a line drawing of a car with marks made that showed 'damage' to the roof. The Mustang had a trimmer shop vinyl top. I've heard of Mustangs that had made it a long way along the assembly line then were pulled off and sent to an independent trimmer shop for a non factory vinyl roof, then resumed assembly after that. kennyg
Old Nov 19, 2009 | 09:26 PM
I know its not a Mustang. But its a Ford.
I found this under the carpet just behind my driver's seat in my 1996 Bronco.
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
