Suspension squeeks and '08 Shelby GT impressions
Old Jul 14, 2008 | 09:15 AM
08SGT1977's Avatar
I have the convertible and love it. It is an automatic tranny which is not available on the GT 500. Mine MSRPd for over $51,000 but I only paid $45,100 for it ($1300 under invoice). It would not surprise me if the prices drop even more with the rising gas prices and housing crash. The Shelby GT has a stiff suspension but it handles great. Did I say I love it?
Old Aug 12, 2008 | 04:35 PM
saleen367's Avatar
Originally Posted by Skyking
I just wanted to add a few thoughts. For those that remember the 1960's Shelby cars, they had the same "issues" but no one seemed to be concerned about it because they wanted the Shelby modified car. If you look at any original (not over-restored) '60s Shelby, you will find ill-fitting fiberglass panels - non functional scoops etc. Back then, those were considered expensive Mustangs and everyone was crazy about them - even with all there cosmetic flaws. I have had the pleasure of own a few of those old cars and still have a couple of them and I can assure you that they have the same kind of issues. I keep hearing people complain about the '07 hood pins. Sometime check out an original 1967 Shelby - they are exactly the same and I can't ever remember anyone complaining about them - ITS A SHELBY... My first new car ever was a 2007 GT/CS (great car) but not a Shelby modified car. In stock form, they are like driving two completely different cars. My SGT is, hands down, the best running / driving car I have ever driven. Yes, you can do the mods for less on a GT or GT/CS, but compare if you will, the current difference in value between a 1968 GT/CS and I 1968 GT-350. The point is that the Shelby name and serial numbers have a huge advantage - especally as time goes by. Why did I not choose the GT-500? Again, a GREAT performance car, but it doesn't have the direct Shelby involvement or serial number that will make it as desirable down the road. Also, as I was evaluating my decision, I just couldn't understand why the SVT car had the tiny stock GT pipes, no side scoops, no "roll bar", not lowered and the fact many more are being built. Now don't get me wrong, this is a GREAT performance car in it's own right, but if you want an authentic "hands on" Shelby modified car with it's special I.D. then you want an SGT (with its little "issues"- although mine doesn't seem to have any). Again if you want a "perfect" production type car, the SVT - GT/CS - or GT is the car for you (great cars - all of them) If you need 500+ HP and a 6-speed, the SVT is your car (and a great choice) Just some thoughts from an old guy that remembers how things were done at Shelby back then.
I concur with Skyking, yet in this day and age (hi-tech, robotics age) people expect and deserve quality as well as the name that goes with the legend.
I am happy to see that in 08 the factory GT grill was replaced with the Shelby unit instead of having the fog lights sawed out and laid over the factory grill. When I saw that last year, I knew I wouldn't buy an 07.
Also, if you look back at 1965, those cars were not very close to the factory Mustang like the SGT is.
$4,547 Street Shelby GT350 - 516 units
Modified K-code 289cid V8 Engine w/306 hp (Shelby applied a "High-Riser" manifold, big four-barrel carb, hot cam, and free-flow exhaust header)
Side-exhaust pipes w/2-inch Glasspak mufflers
Hood-mounted air scoop
No rear seat
Only available in Wimbledon White
Standard GT350 rocker panel stripes
Optional Guardsman Blue Le Mans stripes, athough most were dealer installed
Rear battery on the first 300 or so units produced
Trailing arms located a rear axle borrowed from Ford's big Galaxie to replace the stock, light-duty Falcon assembly. This brought bigger drum brakes in the rear that Shelby fitted with metallic linings, while Kelsey-Hayes disc brakes were used in front.
Also installed were Koni adjustable shocks, quick-ratio steering box, front anti-sway bar, a stout steel-tube underhood brace, and 15-inch cast-aluminum wheels with high-performance Goodyear tires. Finally, the front suspension's forward mounts were relocated for optimum geometry.
15-inch wheels (white-painted steel or cast magnesium Cragar Rims)
no back seat, in order to qualify the GT-350 as a "sports car" under SCCA rules
Can you imagine the cost of all of this in today's world?
According to inflation calculators(http://data.bls.gov/cgi-bin/cpicalc.pl), $4547 for the GT 350 in 1965 would cost $31,585.77 today after inflation.
Don't get me wrong, I wanted one and shopped them hard before buying my GT ... in the end it was the $$$ that steered me clear. If the car had 370-390 hp for that price, I could justify it.
CoyotePremium13
Oct 7, 2015 07:17 PM
GeoWett
Sep 30, 2015 06:40 AM
