Some advice..
Old Feb 17, 2011 | 08:38 PM
coffeeGTCS's Avatar
Some advice..
Hey guys if i learned one thing over time on doing mods to my mustang its research research and then.....do more research so ive come here for some more help....every show i go to people look at my car drool then look at me and goes it kinda has a 4x4 look you should really lower it...im not going to lie being in NY and driving on the roads here isnt the best alot of curbs bumps and ****ty drive ways / entrances to place ..i love the way the lowering looks cause i do feel theres alot of room between the wheel and the car ...im young and every opion i hear from friends is the same old " SLAM IT " ...what do you guys think ?? what are your experiences with springs / drops
heres a pic of how my car stands now
Old Feb 17, 2011 | 10:28 PM
Javdog's Avatar
Just on piece of advise from me if you lower it dont just get springs get the struts as well the ride will be pretty good
Old Feb 17, 2011 | 11:07 PM
mustangray's Avatar
As long as you have the right wheel offset with the overall tire size (about 27") you shouldn't rub tires, the first thing you'll scrape is the nose .
I used Eibach sportlines on the PJ and I hit some heavy bumps and never rubbed a tire.
Old Feb 18, 2011 | 08:05 AM
825LTRGT's Avatar
Don't forget that the CS front fascia is lower and will scrape more than a GT.
Old Feb 18, 2011 | 09:58 AM
Shotokan1509's Avatar
I am on FRPP K's, being very cautious I can avoid scraping the front (watch for big driveway dips/lips, and take them at angles when needed). What I DO have issues with is I drag the exhaust right before it curves up over the rear axle... I need to see if I can tuck it up more. And no, I would not dream of driving mine in NYC.. I thought I ripped the bottom off my Subaru last weekend on a massive pothole on the LIE. Also of course be verycareful of curbs/parking stops as my car will NOT clear them, I tend to back into spots both because its easier to get out later and because the rear has more clearance and I can hang the tail over those blocks which tucks the nose deeper in the spots.
And yes, sorry... you car does need some drop
Old Feb 18, 2011 | 10:30 AM
Water_Junky's Avatar
I have a 2008 GT/CS and I lowered just the rear to level the car out and it made a huge difference. I didn't want to lower the front because it was already scraping pulling into my driveway. Easy one hour job to replace rear springs with leveling springs.
Old Feb 18, 2011 | 01:47 PM
ricksGT/CS's Avatar
Talking
I drop mine 1.5 inch all around Ford Racing Springs ,and I love it rides good still ,and the look is great ,,
Old Feb 18, 2011 | 01:53 PM
ricksGT/CS's Avatar
Talking
Old Feb 20, 2011 | 10:38 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Ride height adjustable coilovers. Problem solved.
Old Feb 20, 2011 | 12:11 PM
goldhillstang's Avatar
I used the FRPP "P" springs which only drop the car 1". Still looks good imo without the wheel touching the top of the wheelwell look. Still a decent ride but you can tell it's firmer than stock. If I were you I would listen to myself first. You're the one that has to drive it. Don't let the "slam-it and it needs 900 hp" crowd tell you what to do. Then again, you can always put it back to stock if it is too low, and sell the parts you don't want. Good luck!
r3ap3r911
May 21, 2014 06:33 PM
Kevin509
Off-Topic Chatter
24
Mar 2, 2012 12:33 AM
tricksixtyfive
V6 Performance Mods
May 29, 2005 08:36 AM
