Interior lights won't come on
Old Apr 3, 2010 | 03:23 PM
bztz4m's Avatar
Gang when I open the drivers to passengers door the interior lights do not come on. The map light is working but not when the doors open. It sounds like a switch is bad but do any of you have any idea to what the problem is?
Old Apr 3, 2010 | 04:09 PM
ricksGT/CS's Avatar
Smile
I'll look into that and see what I come up with,maybe its just burned out,hope its not a short somewhere,I have a good book on all 2005 to 2009 mustangs ,I'll get back to you on this,
Old Apr 3, 2010 | 04:24 PM
bztz4m's Avatar
Old Apr 3, 2010 | 04:41 PM
ricksGT/CS's Avatar
Smile
here are some interior electrical lighting system diagrams,some of this might be help,Interior lights won't come on-picture-001.jpg
Old Apr 3, 2010 | 04:44 PM
ricksGT/CS's Avatar
Smile
here are some interior electrical lighting system diagrams,some of this might be help,Attachment 74080
Old Apr 3, 2010 | 04:49 PM
ricksGT/CS's Avatar
did you check all the fuses and relays,you might need a ( multimeter ) for doing this ,to make sure you do not have a short somewhere.,,I'm doing some more reseach and reading on this matter,
Old Apr 3, 2010 | 05:44 PM
bztz4m's Avatar
I don't have a mulitmeter to check the fuses.
Old Apr 3, 2010 | 07:41 PM
frank s's Avatar
Is no-interior-light-on-opening one of the many options controlled by some arcane set of switch sequences?
Old Apr 4, 2010 | 11:24 AM
GottaHaveIt's Avatar
dimmer switch ?
yah it's silly but I've been there on that one !
Old Apr 4, 2010 | 11:45 AM
PTRocks's Avatar
Ron,
You can check the door switch circuit if you have the IUP. The message "door ajar" appears in the information window in the speedo when the car is on and a door is open. Compare the message response between the driver and passenger doors to verify that the Smart Junction Box (SJB) knows the door is open.
If the proper message doesn't appear, then there is a problem somewhere along the circuit from the SJB to the door switch. First place to look is at the door switch, second place to look is at the connector to the SJB.
Another possible cause for lighting issues has been the water infiltration problem that a number of people have experienced. The firewall water leak gets the SJB wet, and strange things start to happen later on.
Old Apr 4, 2010 | 05:37 PM
bztz4m's Avatar
Thanks for the info guys.
Old Apr 5, 2010 | 01:26 PM
bztz4m's Avatar
The problem is fixed
Well I took the car down to a friend who owns a Mustang repair shop, he checked all the fuses and they were fine. The problem was who ever wired the alarm from the dealer did not crimp the wire to the fuse box correctly causing the short to the door lamp.
Ron
Old Apr 5, 2010 | 01:30 PM
PTRocks's Avatar
Glad you got it resolved.
Old Apr 5, 2010 | 01:47 PM
bztz4m's Avatar
Yeah me too.
Old Apr 6, 2010 | 03:39 PM
Ron
I thought was on your 07/09 Mustang that have factory alarms don't they if so and it was why would someone go after market ? Glad your good now.
Old Apr 6, 2010 | 04:50 PM
bztz4m's Avatar
My GT/CS did not have the factory alarm so I bought through the dealer who had someone they contract to do the installation.
Old Apr 6, 2010 | 10:54 PM
Well if under warenty still the dealer is on the hook are they not they farmed it out ?
Like when I had my rust proofing done the retards went mental I totally freaked about the crap work and was apploaded by some Ford staff and that farmed agent was siht canned right after.
JT_Kwik
Nov 29, 2022 01:45 PM
FromZto5
75
Oct 5, 2015 02:27 PM
DrisStang
Sep 14, 2015 06:20 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
14Glassback
Sep 11, 2015 04:50 PM
